Opinions Please...Shift light?
Old Mar 17, 2005 | 06:24 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Opinions Please...Shift light?
Which is the easiest install, and is favored best...Raptor or Harlan? I need to purchase soon for my FRC, Thanks!
Old Mar 17, 2005 | 07:18 PM
jmzvet's Avatar
jmzvet
I like the Raptor.
Old Mar 17, 2005 | 07:24 PM
ICULUKN-C5's Avatar
ICULUKN-C5
raptor
Old Mar 17, 2005 | 07:26 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I just bought a Raptor......love it!
Old Mar 17, 2005 | 07:35 PM
mdhmi's Avatar
mdhmi
My Raptor has been fine. The Harlan shift lights are very nice, but, you may end up waiting a little while when you order.
Mark
Old Mar 17, 2005 | 08:55 PM
highpressuremax's Avatar
highpressuremax
I like my Blue Chrome Raptor, nuf said.
Old Mar 17, 2005 | 09:04 PM
Patches's Avatar
Patches
Raptor is well made, significantly smaller and easier to program. It can also be changed much faster. Harlan is good quality from what I've seen as well.
I designed a bracket for the Harlan for a buddy who had one based on my smaller Raptor bracket on the left.
Here's my Raptor in it's first mounting location, on the upper A-pillar.
And in the custom gauge pod bezel I made for it.
Old Mar 17, 2005 | 09:39 PM
3Vettes@Home
Cruise-In V Veteran
WOW Thanks guys! just the information I was looking for Thanks Patches...as always fantastic information...with Pic's
Old Mar 17, 2005 | 09:57 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Here's a pic of my raptor I mounted in the A-pillar duel gauge pod.
Old Mar 18, 2005 | 12:50 PM
cenzo's Avatar
cenzo
Default hook-up?
Just how involved is the electrical part of the installation? Using the shift light on the hud can be suicidal.
Old Mar 18, 2005 | 12:56 PM
Patches's Avatar
Patches
Very easy to install. A hot, a ground and a tach signal wire is all you'll be connecting. Use Flyin'Brian's install instructions to tap into the wiring harness right at the driver's side dash area.
http://forums.corvetteforum.com/showthread.php?t=619162
Setting the light involves just three dip switches (set to 4 cylinder for the LS1/6 dual coil pack setup) and two rotary switches to pick your rpm trigger. Plus, you can change the RPM setting anytime you like within about 10 seconds.
Old Mar 18, 2005 | 12:57 PM
ICULUKN-C5's Avatar
ICULUKN-C5
3 wire installation power, ground, and tach.
Old Mar 18, 2005 | 03:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXCELLENT INFO!!!!!!!!!
To Opinions Please...Shift light?
