From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Originally Posted by Icemanskis
The above posts are right in the area. You need to call the manufacturer of the cam to determine what is the max legal setup you can run and still pass emissions. Check out futral motorsports. I spoke with them and they were very helpful (more than anywhere else) and clearly explained everything I needed to know. I also need to remain emissions legal and they recommended their F4 cam 226/226 at 114 lsa. They said that is generally the most radical you can go.
I AGREE with this 1000%, call ALLAN FUTRAL he is a great guy and an LS1/6 Tuner and CAM GURU!! TELL him your goals, usage and objectives and he will set you up with the perect cam!!!! STICK with the advice of a cam PROFESSIONAL EXPERT and that would be ALLAN FUTURAL!!!
I'm having ECS install the F4 cam 226/226 at 114 lsa cam for the very same reason - pass emissions with the largest cam possible.
