Engine Exploded! Dipstick Shot Across Shop
Old Apr 18, 2005 | 11:57 PM
ajderzie's Avatar
ajderzie
Default Engine Exploded! Dipstick Shot Across Shop. NEED ADVICE
So here is the story. My vette and I can never catch a break. A few weeks ago, I went to start her up. Nothing but a click. Got a new battery: the obvious problem. Nothing but a click. I take it to the shop. Faulty relay. While there I decide to finally get my H/C done. AFR 205 heads, 224/228 112 cam, FAST intake, throttle body, Kooks headers, electric water pump, LS1edit dyno tune and painted my calipers black with yellow lettering (sick looking btw). The 3rd run on the dyno hit 460 RWHP then bam, the oil dipstick shot out like a gun! Hmmmm loose dipstick? One more run (partial run actually) bam! Gaskets blown out from under the heads and the dipstick is somewhere in orbit. I guess the crankcase got pressurized from a leak from one of the cylinders. Now after two to three weeks without my vette, I'm looking at another month to tear apart the engine and change the pistons, rings, rods, crank, etc to new forged parts. I'm so bummed and I'm sure the bill is not going to be pretty. Feel free to take a guess at what its going to cost. I wont know until tomorrow but I would appreciate a ballpark figure.
Old Apr 19, 2005 | 12:09 AM
ICULUKN-C5's Avatar
ICULUKN-C5
that sucks.. price will depend on what you are doing. You already have the good heads... lower the compression and add turbo or supercharger... its only money.
Old Apr 19, 2005 | 12:35 AM
army2000's Avatar
army2000
St. Jude Donor '11
Man that's a really bad case of Mod fever. It's never a good idea to run your engine hard after a serious mod session like that. I know people do it, but you have to let things settle first. Sounds like you have a hand full there. Take it easy and good luck.
Old Apr 19, 2005 | 08:49 PM
Vette X 3's Avatar
Vette X 3
So, where does your engine builder check in on this problem? I don't subscribe to the break it in gentle theory although it sounds like a good idea. If built properly, your motor should have survived many a dyno pull immediately after a short run just to make sure no leaks, etc. My motor had thirty dyno pulls back-to-back during a 4-5 hour tune session, before it was done with LS-1 edit and to everyone's satisfaction. I would be asking him what he is going to do about is since doing a H/C swap should have addressed just about everything that could have caused this. I know the surface finish non the deck is very critical to the head gaskets sealing properly and many a motor has been ruined by missing this detail either on the head or the deck. Good luck getting it straightened out before the summer.
Bill
Old Apr 19, 2005 | 08:56 PM
yellow01's Avatar
yellow01
Cost - shouldn't the builder field all the cost - especially if it hasn't left his shop. Heck the dyno is just TESTING his work. If it blows up in TESTING I'd say he didn't do too hot of a job.
I'll wait to hear more detail but if you get this pinned on you, and that is common tuner practice, that will sure save me some mod money down the road. No way would I ever let them touch my car if they charge me if it blows up before it leaves their shop!
If nothing else the first time the dipstick flew across the room should have been a clue...their not supposed to do that...
Good luck getting it resolved!
Old Apr 19, 2005 | 08:57 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Bill
It sounds like the problem was a bit deeper than H/C. If it blew the dipstick out, the engine had serious piston blow by. That would be caused by bad rings of a hole in the piston (maybe caused by inproperly clearanced heads) but, I doubt it. You really won't know until they tear the engine down. A ballpark guess on repair cost would be 10K. Higher or lower depending on what parts are needed and what brand you decide to use.
Old Apr 19, 2005 | 09:07 PM
Vette X 3's Avatar
Vette X 3
I think when the heads were off, these things would be rather obvious wouldn't they? How would the rings have gotten that bad between the last time he drove it and the mods? True enough that the tear-down will tell a story, but explain to me how the head gasket blew out after a head change from bad rings?
Old Apr 19, 2005 | 09:19 PM
yellow01's Avatar
yellow01
I'd agree except the head gasket blew... maybe I'm having a dumba$$ moment (happens) but aren't they on the compression side of piston?
I know the LSx has a negative deck height (right) but the rings should never clear the head gasket...
Old Apr 19, 2005 | 09:35 PM
Z06ufgrad2002
The blown head gasket sounds like a separate issue from the dipstick flying out of the engine. The head gasket issue could have been a faulty part or poor installation. But, in either case I don't think it was related to the dipstick and piston blow by.
Old Apr 19, 2005 | 09:37 PM
Vette X 3's Avatar
Vette X 3
Can I make a guess? I'm guessing that you will find "smileys" on top of every piston except the one with a big hole in it. Sorry Hope I'm wrong.
Bill
Old Apr 19, 2005 | 09:42 PM
Z06ufgrad2002
Bill
I thinking you're getting warm.
Old Apr 19, 2005 | 11:02 PM
mdhmi's Avatar
mdhmi
I don't know the details of the car in question, but, let's say I bring a total POS motor in for a cam swap.. The shop puts in a new cam.. Motor blows on the dyno.. Is it the tuners fault?
Forged short block is going to run $3,500 - $4,000.
Mark
Old Apr 20, 2005 | 12:05 AM
ajderzie's Avatar
ajderzie
I still don't have an answer yet from the tuner. They started taking apart the engine. I seriously hope its not the block otherwise I'm going to end up having to buy that plus forged rotating parts.
Do you guys think the tuner broke my engine or there was some weakness that manifested itself when the added horsepower became an issue? Also, who should pay for what under what circumstances? ie. should I buy the forged pistons/crank etc and they install it? The tuner is a pretty nice guy but I'm sure he is stressing as I am about this. Problem is, I don't want to get walked all over about this. I'm willing to do what is fair but I'm not sure what constitues fair in this situation.
Old Apr 20, 2005 | 12:50 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
who did the work for you
Old Apr 20, 2005 | 01:07 AM
George8211's Avatar
George8211
If I were you, I would do some fast learning of the inner workings of motors. Get some knowledge so you can understand what went wrong, and then why. Hopefully your shop is honest, but it's always best to be an informed customer for your own protection.
There may have been some thing wrong in the set up... in the valve train causing valves to slam into the pistons. Your dipstick shot out because the lower half of your motor suddenly became pressurized. Could be broken rings, cracked piston, or a hole in a piston.
What appears to be a head gasket... could be a cracked head due to valve train trauma. Or it could have just been your engines time. Sucks not having your Vette. Going forged should keep you in the driving business... instead of the garage business. Cost is gonna depend on how many parts you can salvage from this situation.
Hopefully your not sweating it too much. Hang in there cheif
Old Apr 20, 2005 | 08:01 AM
yellow01's Avatar
yellow01
Mark
Understand...but that doesn't sound like the issue here.
The suggestion above about valve/piston contact is the only one that makes sense to me...Oh well, sorry for the speculation - we'll just have to wait for some failure analysis.
Old Apr 20, 2005 | 08:25 AM
ajderzie's Avatar
ajderzie
How can you tell if valve piston contact was the cause?
To Engine Exploded! Dipstick Shot Across Shop
Old Apr 20, 2005 | 08:46 AM
wilerty's Avatar
wilerty
Valve piston contact can caused by many things ... wrong pistons, broken cam, broken timing chain/gear, wrong rockers, broken valve spring, improper clearance in assembly, dropped valve, etc, etc, etc. It could be a failure of a mechanical part just as easily as improper assembly.
I haven't built an engine since the 60s ... but I used to always assemble my own back then ... just so I had no one to blame but myself. You're in a tough situation ... you'll just have to play the hand out.
Old Apr 20, 2005 | 09:12 AM
WhiteDiamond's Avatar
WhiteDiamond
St. Jude Donor '15
To actually launch a dipstick as you describe, the piston would have to fail right at spark and allow the expanding gas to propogate through the bottom end. Depending on what happended to the various chunks of metal, we could explain the head gasket leak.
Todd
Old Apr 20, 2005 | 09:17 AM
jimcork1's Avatar
jimcork1
Default Check For
Be sure to check for the small socket that was left on top of the piston before the heads were put on. My bet is something was left in a cylinder and punched a hole in the piston during run up. Then the high pressure built and blew out the dip stick. If there is hammer dents on a piston it is a good indication something was left in. So be sure to look for many dents in the piston top that is damages. If you find this I would expect the builder to foot the bill.
