A4, blackwing, corsa indys, 3.42 gears added last year
this year: added 1 3/4 headers w/high flow cats, xpipe -car was tuned last year because of the new gears:
Problem: headers gain NO new power - car's time in the 1/4 did not change: car was dynoed by the same person on the same dyno at about the same time of year -not too many variables!! Wazz up????
Dennis, The track wasn't running that great saturday. Not too many people posted decent times. I did because I was the first one out. After that it was all downhill. Also how many miles did you put on your car before taking it to Milan? I think your time will be much better the next track event.
Thats wierd b/c same thing happened to me! I used the LPEs LT, borla, BUT stock with cats. One reason i thought was my heads. On the dyno you can tell they were some issues not sure what but the tuner easily noticed. Whatever i added i got no increased power. bigger injectors, LS6 intake, then the headers.
So then I bought a LS6 engine with ported/polished and milled LS6 heads, and a nice comp cam and etc. Power is there now!
I did hear some people talking about header/ heads combo. I guess certain headers work better with certain heads. With stock heads i heard you dont gain much if at all. So thats what im guessing happened to me.
You say the car was tuned last year following the gear swap?
It will need to be tuned again following the headers.
Adding the LT's can definitely alter your AF ratio. You can't compare racing in near perfect temps in Oct to racing in 70 degree temps into a strong head wind.
A well known tuner advised me that headers should be about the last thing I do. He said a stock engine would show little or no gain because the stock manifolds were very good,
A lot of people thought that was crazy. I guess you're finding out.
problem is you won't see much gains from a lot of other things unless you do headers at some point, so a lot of people go ahead and knock those out first so they'll see more from their other mods.
At some point you're gonna need them if you do much to the engine, as in heads and cam or SC. But if you're leaving the engine stock then why bother? From what I'm being told by a well known tuner it's a waste of money. He also was talking about my 2003. Maybe an older model would be a different story.
hmmmmm......I added headers and picked up about 20 at the wheels and another 25-30 with the cam.......has your "tuner" ever looked at the stock manifolds compared to aftermarket headers?? I can't believe anyone would tell you that but WTF do I know
My first question would be what did the tuner do to tune for gears? Were fuel and spark tables modified, or only the gear ratio and shift parameters. I picked up 25 HP with my headers, and the installation results were immediate the first time I drove the car. What size are the headers?
As I mentioned another car similar to mine with no tune went from 303 rwhp to around 327 rwhp with the same change. Asked several tuners and professional vette mechanics and they all agreed that power from a header change should show up without the re-tune. The tune will max things out and correct any "soft" spots in the power curve.
Mark
True, but you should not be able to compare Milan to Lapeer Dragway either!! My driveway has better traction than Lapeer!! These factors should affect things but ZERO change in power on the dyno and times on the strip?? I don't think so. Maybe Feng- Shui is playing a roll!!
Once again, compared with other cars, not the case - see above response. Also, how many Forum advertisers claim zero response with their headers??
Your results are the common response seen on many past threads on this Forum - you got what is expected.
No, he did a full tune at that time not just gear ratio,etc. You got the expected results. What make are your headers? The headers are 1 3/4" into 3".
