Change heads
Old Jun 11, 2005 | 09:31 PM
glind46677's Avatar
glind46677
Default Change heads
If I were to change the heads on my 2004 automatic what would you recomend? I have headers, B&B exhaust X pipes and Vararam. Dont race the car just looking for a little more punch.
Old Jun 11, 2005 | 10:42 PM
mdhmi's Avatar
mdhmi
AFR or some worked over LS6 heads. Put your money in a good convertor and gear combo before heads.
Mark
Old Jun 11, 2005 | 10:47 PM
2KREDVert's Avatar
2KREDVert
The first thing you should do is a 3.42 rear end. I would stick with the stock converter. Get a 224/224/114 cam, a pair of Stage 2 LS6 heads and a good tune. That's the best bang for the buck. Go to a converter if you are going to track the car, otherwise stick with stock.
Old Jun 12, 2005 | 10:03 AM
vettenuts's Avatar
vettenuts
In my opinion, care must be taken with the heads only approach. I am currently researching this, and while I love the AFR 205's, I think installation without a timing chain upgrade is asking for a problem down the road due to the beefier valve springs. My current thought is to modify some LS1 heads with Z06 valves and titanium retainers to keep the valve train very light and then go with the Crane 1.8 rocker arms to get a little more open duration and lift on the valves with the stock cam. I don't want to overload my timing chain though.
Old Jun 12, 2005 | 11:28 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I agree, doing a good h/c will reap alot more benefits than heads only upgrade. If money is tight, id do a nice cam-only upgrade.
Old Jun 12, 2005 | 11:34 AM
fsuforever's Avatar
fsuforever
i would do the cam only if money is tight the gear & converter route is very expensive & u will see more rwhp doing a cam change than u will doing a gear & converter change my 02 worth whatever u do make sure its done properly i am very paticular on who works on my vette dont want some so called mechanic stripping bolts , etc
To Change heads
