Ported TB Suggestions
Jun 12, 2005 | 06:38 PM
What is the consensus on the best ported throttle body to mate with an LS6 manifold?
Jun 12, 2005 | 06:56 PM
Jun 12, 2005 | 06:58 PM
I had Mark Shaner do mine. Excellent work.
Jun 12, 2005 | 07:05 PM
If you don't want to do it yourself, I have heard good thinga about Mark Shaner
Jun 22, 2005 | 09:58 AM
Is there a how to on this one. Can I do it with my dremel? THanks,
Jim K.
Jun 22, 2005 | 02:37 PM
Cruise-In V Veteran
St. Jude Donor '09
Quote:
http://www.lingenfelter.com/store/tbls1tk.html
Jun 22, 2005 | 02:49 PM
St. Jude Donor '12-'13-'14
do you port both sides or the intake side?
who is mark shaner ?
Jun 22, 2005 | 04:03 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Port only ONE side! Port the side facing the front of the car. The walls on the TB are VERY THIN!!!!!! If you hog out too much, you will break into one of the cavaties.
I did my own and it worked out well. All you need to do is smooth and straighten out the opening. You can get fancy and fill in the big square opening with J B Weld and use a brass tube for the air hole.
BC
Jun 23, 2005 | 01:00 AM
St. Jude Donor '06
Quote:
Yep.
http://forums.corvetteforum.com/show...enu_1549300142
Quote:
http://www.s2performance.net/
