Air intake system
No the original location was right after the maf and it split into two filters.Now its behind the plate,but the pavement ic cool to the touch and its 68 degrees tonight.Also what is the benifit of two 3 inch filters if the hole in the maf is only the size of one of them.It cant need both of them to get adequete air can it?
I think that what you've got is for show, but that's just another guess. Big help aren't I.
No, seriously, I agree that you are probably picking up heat from the radiator.
The Vararam is a sealed system of ducts, (once you get behind it's water drainage openings) just like the ducts in your central air conditioning at home, so this is not a problem for it.
People like to claim that it is poorly designed and thought out. But the engineering and planning which went into it is a lot more complex than you might think, and simply adding a "trough" / air dam or a pipe to an existing system will not yield the consistent results it does.
Its your time, but you just wasted whatever time it took out of your life attempting to jury rig a cold air intake system to match just one of the performance of the Vararam. Time you'll never get back.
Someone else here wasted at least as much time and well over $100.00 on an "air dam" and wound up removing it a few weeks later, same as you will that pipe you put in. But I doubt that pipe stays on your car as long as that dam stayed on his.
If you want cold air, get the Vararam
The Vararam is a sealed system of ducts, just like the ducts in your central air conditioning at home, so this is not a problem for it.
Someone else here wasted at least as much time and well over $100.00 on an "air dam" and wound up removing it, same as you will that pipe you put in.
That analogy applies for the Vararam
He was attempting to duplicate results, and his efforts were every bit as futile as the last guy's.
I have been reading up on this wide band tuning crap most of last night and tonight.
That LC1 I ordered is going to be a tough install. Thats if I install it.
Was up last night/this morning till 3 AM and still confused about the install and wiring.
Ok so i guess i wasnt clear.If i wanted a vararam i will buy one.Jury rigging isnt my game,i was testing the cold air theory to see if there was actually cooler air in the nose rather than in the engine bay.
I knew i would get a "Get a vararam" from someone. It seems every time somone has a question about a system,there is always someone who instead of going over the actual question,has to spout"Get a vararam".You actually think i havent been reading this entire thread,along with the countless others about this topic.I was mearly trying to emulate this piece of ****!!!!
I built a box around my Blackwing and I notice it gets hot. That was only one high speed run to test it though. I need to go back and see what else you posted and maybe I can add more. Are you recording temps via the PCM or a sensor down by the filter?
Sorry i got a little pissy this morning guys.I just knew id hear a "get a vararam".I was ready to attack.I cant belive im actually learning anything from this thread but so far its been A little useful.
