Air intake system
The car shows and Corvette lunches prove to be very important as far as spreading the word. Roger and I have attended the last few and I have 2 more planned this year as well as a few other guy's doing monthly events.
A. Your car will NEVER flow more air to the intake than with NO filter at all. Any filter is restrictive!
B. Unless the system is pressurized you will never FORCE air into the intake. The engine will DRAW air in through the throttle body. Period!
And if you do pressureize the intake system the air temp will rise as the speed/pressure/flow rate increases. Thats physics boys.
C. Stop calling them cold air intakes! It is not cold air that is drawn in. It is cooler air than the engines intake temp that is used.
Okay I will respond to your facts CB.
A. Agreed, but I think the idea here is to select the highest performing air intake system. Althouth I do believe the vararam will out perform a vehicle with just the air cleaner off. The reason for this is the car would recieve cold air from outside the engine bay.
B. Ok, your over my head on this one. Maybe you can explain why the vararam significantly out performs other aftermarket intakes.
C. Well CAI seems to be the accepted term. Cold, cooler, ambient you choose.
The vararam significantly out performs other after market intakes. This includes intakes that receive ambient air. The only thing I can see the vararam does that the others do not is channel the ambient air in through inlet tubes, (ram air).
I am at a point in this discussion where I have a hard time just accepting some one quoting a physics book. I have read enough reports from other forum members and used the vararam on two C5s with several hundred qtr mile runs to know that the vararam does indeed outperform the other designs. Now to me the only relevant discussion is why? I do not know. The fact the air is rammed into the inlet tubes intuitively seems to be a factor, but some people who seem to know something about physics say that is impossible.
Well it may be impossible. I have to doubt it though.
Inlet tubes are the worse design I have ever seen. Rectangular, small and have bends. Where are you getting ram air? Do me a favor. Go to google and do a search on dynamic and static air. I think then you'll see the light.
I'll call tonight regarding email.
And that is the naysayers big dilemma, Shurite.
They argue till they are blue in the face that there is no ram air, no cold air............................... but then offer no explanation as to why the Vararam outperforms the other intake systems. Thats even IF they acknowledge that it does. The testing which I did and the reports of others clearly show that it does. Very few are denying now that the Vararam works.
I am speaking specifically of the guy who calls himself "The Vette Guru". He attempts to use a "fluid mechanics" argument that ram air does not exist in automobiles. But from what I recall, does not even acknowledge that the Vararam outperforms the others. This makes it convenient for him . Hence he does not have to offer any explanation as to why the Vararam kicks the others in the ***.
To Korreck's credit, at least he has offered up what he thinks is an explanation for the Vararam's superior performance, even if it is off base.
One guy, EHS, who argued against the Vararam and for the Blackwing until he was blue in the face, has seemingly disappeared from the forum
He pretty much left Korreck to "face the music" by himself as it were following my performance results.
I have not seen a post from EHS since 4/15/05, the day befor my historic runs proving the efficacy of the Vararam.
Which brings me to the response by CB99Coupe. A question for him.
If there is no ram air and no cold air, then what explanation would you offer for the Vararam's superior performance vs the Blackwing?
1. The PCM starts to pull timing when the IAT reaches 90*
2. Power is lost because of the hotter air. The standard correction for temp. is the ratio of actual temp. divided by the temp. at standard conditions (usualy 68* F) The ratio is in absolute temp (ie. 460 + temp. in *F ) so this can be a large amount of horsepower.
Even those systems drawing the air through the shroud are drawing hotter than ambient when the vehicle is stoped.
I monitor my IAT continuously at the strip and keep my hood open as long as I can befor I stage.My best times and trap speeds ALWAYS come when I am able to keep my IAT close to ambient at the line.
I do the same,what is your intake air temp when say cruising at 70?
I looked at your mods and I don't see how you can run heads up. I assume you bracket race. If so the worse thing you can do is try to keep your engine cool. You cannot launch at the same temp each time so it would be impossible to predict your ET.
Last but not least, a well tuned car does not pull timing at 90 degrees.
Just wondering because i have a rm racing twin flow and im never closer than +3 degrees from outside temp.At a stoplight or sitting i go all the way to 15 degrees above ambient.It will never get to ambient for some reason.I see the points made as to cooler air entering the system,but ram air?I would think it would take ALOT of forced air to enter the intake to even equalize the vaccum of the engine.BUT,i guess if my engine is a -20 psi normally at wot,then if i can even get it to ---- -19,theres that much less stress on the engine.
This is what I was referring to: "One advantage of the VR that has not been discussed is the fact that the VR is drawing cold air (ambient air for those that want to play on words) even when the vehicle is stopped. This is a big advantage at the starting line."That's only true at idle and doesn't impact my performance. Look at the track temps. With the VR you're drawing hot air but off the pavement and not the radiator area. I think it's a wash.
At a stop light or sitting I never get to more than 3 degrees above ambient.
The way the Vararam is designed, the only air it can take in is ambient air. Which is "relatively speaking"......cold air when compared to underhood air.
http://forums.corvetteforum.com/show..._id=108&arch=1
1. It needs no forward movement of the vehicle to receive ambient or cold air. The vehicle starts the race receiving ambient air.
2. Vararam filter is very high flow design.
3. The sealed design and location of the intakes on the front of the vehicle in the airstream creates high pressure on the outside of the air filter. I believe this creates a situation in which there is less parasitic HP loss in the engine. Is this ram air effect, well not really but it has become the popular term for this sort of set up.
