Check engine light....Help please!
Old Jun 17, 2005 | 07:25 PM
Scubanme's Avatar
Scubanme
Default Check engine light....Help please!
I was driving home from work on the highway at about 65 mph and the check engine light came on so I checked the odometer and it read 45,725 miles. I thoght maybe it was for some routine maintenance so I checked the mileage. I checked allfluids and all was ok except that I was a little low on power steering fluid so I put some in and the light is still on. I never really thought that would be it, nor did I think there would be any sensor to show low power steering fluid level.
Any ideas?
Thanks for any info.
Old Jun 17, 2005 | 07:32 PM
2000vert's Avatar
2000vert
Use the dic to retrive codes. I saw on the forum a link to look up the meaning of the codes.
Old Jun 17, 2005 | 07:48 PM
VetteSiNz's Avatar
VetteSiNz
Check your Gas cap .... probably it's just loose or came off.
Old Jun 17, 2005 | 08:15 PM
Scubanme's Avatar
Scubanme
I just checked that to no avail.
Thanks for the idea.
Old Jun 17, 2005 | 08:16 PM
Scubanme's Avatar
Scubanme
I guess it's time to pull out the ease scan program.
Old Jun 17, 2005 | 08:25 PM
VetteSiNz's Avatar
VetteSiNz
The next possible cause is the MAF or check anything that is tied up in your emissions.
Old Jun 17, 2005 | 08:54 PM
RonJ's Avatar
RonJ
Do a search on trouble codes, should be all sorts of info available on how to retrieve and interpret the codes.
Ron ...
Old Jun 17, 2005 | 09:14 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Why? you don't need any scanners Code lookup
Old Jun 17, 2005 | 09:16 PM
Scubanme's Avatar
Scubanme
I just called a good friend who is an excellent mechanic with a smog liscense and he owns his own shop, he informed me that it probably has something to do with smog. I hooked the ease scanner program and laptop. it showed up as a "Evap system small leak", so I cleared the DTCs. Could it have been the gas cap? I will drive for a bit and see it code comes up again.
Thanks to all the great member contributions! You guys are the best.
Old Jun 17, 2005 | 10:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Youbhave everything that you need to diagnosis your own car! Dont really need a scanner.
Here is a good link:
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Codes_Page.htm
BC
Old Jun 17, 2005 | 10:10 PM
Scubanme's Avatar
Scubanme
Thanks Bill for the link.
The Scub
To Check engine light....Help please!
