Lost Locking Lug Nut Key -- Need Help
Old Jun 29, 2005 | 10:43 PM
newgene's Avatar
newgene
Default Lost Locking Lug Nut Key -- Need Help
I just changed out my shifter, and for some reason when I took the locking lug nut key out to remove the console, I somehow lost it. Does anyone recommend a way to get the locking lug nuts off. Honestly, I think the locking nuts make no sense because I usually just keep the lock in a place that a thief can get to it anyway. I have 2 questions:
1.) Can the local GM dealership order me a replacement key for the lug nuts (maybe by VIN number)?
2.) Can these be removed easily without the key? I really don't care if I have locking nuts on the factory wheels.
Old Jun 29, 2005 | 11:19 PM
RWhite's Avatar
RWhite
Do a search on this forum, but a certain size socket will fit snuggly over the locking nut and remove it fairly easily. I just took mine off early on and used some nice looking chrome lug nuts. Thieves will have the proper tools to remove the locking nut (as I just explained above!).
I just found this. A search yielded this: "Usually a 19mm socket and a hammer is a replacement for missing lug keys."
Old Jun 30, 2005 | 02:52 AM
Shark Racer's Avatar
Shark Racer
Don't take that to heart. There are a number of people who would actually follow that advice:
1) People who are ignorant. I have been in this category in the past. This technique causes huge stress on the wheel spindle. NICHT GUT.
2) Thieves. What do they care about your spindle?
3) Lazy mechs(also possibly ignorant.) See 1.
Shops have tools that will take these things off... usually permanently. You definitely don't want to damage your suspension to take a $5 lock nut off though. Personally I agree with you, I don't use 'em.
-Steve
Old Jun 30, 2005 | 06:31 AM
Z06 Steve's Avatar
Z06 Steve
Take a 12 point deep socket that fits over the lugnut.then tap it on with a hammer till it bites.put the socket wrench on and loosen them.They come off like butter.did mine in 10 min.
Old Jul 1, 2005 | 09:58 AM
RWhite's Avatar
RWhite
-Steve
Thanks for the compliment . You don't know me, so I would not make such a childless statement.
NICHT GUT
"It IS good" if you know what you are doing!
You use a rubber mallet, a slight tap and the socket fits snug enough over the locking lug nut to perform the loosing. Twist it slowly and it comes off. No damage (to socket, locking nut or rear end). You act like someone will haul off and swing as if using a sledgehammer!
I removed mine as I referred to earlier. I can't believe your statement of ruining the rear end. Done right, it will nowhere near ruin the rear end. If it did, it would not have stood up to my many 10 sec. runs, etc. etc.
Old Jul 1, 2005 | 10:49 AM
C5 ChemE's Avatar
C5 ChemE
Newgene... I swapped my stock lugs w/ the chrome House of Wheels lugs, so I don't need the key anymore... Only problem is, one of the wheel locks is HAMMERED into the key cuz it was almost stripped. If I can get the lug out of the key, I'll send it your way!
Chris
Old Jul 1, 2005 | 04:04 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are a dozen or more of the keys series. The dealer has the set of keys. My dealer lost my key and had to order me a new one. Go to the dealership and ask them to get the correct key for your car.
I agree, the socket method does work in a pinck and it will not hurt anything but the finish on the lock!
Been there done that!!
Bill C
Old Jul 1, 2005 | 04:23 PM
Shark Racer
Rwhite -
I apologize for insulting you. I still would rather not follow this technique. All of the times I've seen it done, the perpetrator was going full bore with a hammer as if they were shaping a sword.
The last time I mentioned this technique as advice in a thread, I was attacked by a number of people.
Another technique for removal is to spot weld a junk socket to the lock nut, this obviously ruins the nut, and I don't know how easy it would be to do on a C5 wheel anyways.
-Steve
Old Jul 1, 2005 | 04:57 PM
RWhite's Avatar
RWhite
Rwhite -
-Steve
I went out and looked at the socket I used. I imagine it might be useful to use one of those that has a bunch of "points". This way, it can grip easier w/o hammering it home. Also, the socket I used was a short body type.
I remember when I did the removal, it slipped the first time, but after I moved the socket slightly one direction, it gripped and the lug nut came off.
Old Jul 1, 2005 | 05:27 PM
Z11409's Avatar
Z11409
Use what your locale wheel thief uses------http://www.autobarn.net/emlugnutrem.html
Old Jul 1, 2005 | 10:38 PM
Admiral Fairway's Avatar
Admiral Fairway
Pep Boys and other Part stores carry a socket that is used to remove locking lugs without the key. The socket has left hand threads inside of it, so when you use a impacet wrench to install the socket going to the left it screws itself onto the lug and then removes it.
Old Jul 2, 2005 | 02:39 AM
white90conv's Avatar
white90conv
This thread makes it pretty clear that locking lug nuts are a waste of time. A thief either breaks into the car and gets the key from the console or he uses a standard socket or a universal unlocking tool from Pep Boys.
Old Jul 2, 2005 | 08:09 AM
itchynackers's Avatar
itchynackers
Look with the rest of the car's paperwork. There should be information for reordering the correct lug key. Should be in with the 4 original lugs leftover from dealer.
Old Jul 2, 2005 | 09:53 PM
SFVetteman's Avatar
SFVetteman
When my key was lost, I first went to the delear but they didn't have a complete set and none would fit my locks. I contacted McGard, who makes the locks, and they told me to send them a picture of the the wheel lock and they would send me a replacement.
To Lost Locking Lug Nut Key -- Need Help
