2000 vert running strange
Old Jul 1, 2005 | 04:47 PM
2000vert's Avatar
2000vert
Default 2000 vert running strange
I just got my 2000 vert back from the dealer. The dealer found a crack in the block and the extended warranty replaced the engine with a long block. The car is stock. I drove it for 200 miles without getting on it. I jumped on it a little today and is has a slight surge and no way has the same power as before. I do not know if they did anything to the computer. Do you need to reset the computer after replacing the engine? Is there anything I can do myself to try to fix the problem? I really do not want to take it back to the dealer unless I have to. Thanks in advance for any ideas.
Old Jul 1, 2005 | 08:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the codes. If there are any, post them here.
Bill
Old Jul 1, 2005 | 11:02 PM
2000vert's Avatar
2000vert
The codes are pcm p0332 and ipc b0516. The vette fells like it may be missing intermitly
Old Jul 2, 2005 | 12:09 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,,,,,,,,the P0332 code is giving you some problems. Your Knock sensor circuit is OOC and affecting your ignition timing and thus your performance!
Do you or have you ever washed your engine with a garden hose?? If so the sensors can be damaged by the water standing in the valve valley. My recommendation would be to remove the intake manifold and take a look at the sensors and wiring harness!
BC
Old Jul 7, 2005 | 11:47 AM
2000vert's Avatar
2000vert
Thanks I will give it a try
To 2000 vert running strange
