We've had it for years down here in Milwaukee and I've never had problems. Gas mileage seems to be slightly less than "real" gas based on trips to places where I can get it (although the EPA disputes this). Anyway, I would not think that it would cause the type of problems that you are experiencing.
I have had problems with my 2000's fuel guage whenever I filled-up with a fuel that has less than 94 Octane. Everything would be fine until I hit just below a half tank and then it would suddenly show that I was out of fuel...a little shocking the first time! Appearently it has something to do with the type of materials that GM used in the sender.
I don't think you will find fuel without either Ethanol or MTBE, and MTBE is in the process of being removed so this is an issue you will likely not escape. Many of our local stations are also making the switch from MTBE to Ethanol and I have not had a problem, but I am now using Fuel Power in every tank and hope that is helping. A friend and I filled at the same Sunoco station a couple of years ago and both of us were bitten by the fuel gage problem shortly thereafter. Run out that tank and fill at another station and see if the problem goes away.
To add a little of my experience. All I know so far is that if I fill up at Arco my fuel gauge acts up (drops to empty periodically, generally after half a tank is gone). As soon as I re-fill with Chevron or Shell everything works fine.
I'll have to pay attention to the additives in gas to see what may be causing my fuel gauge problem.
[QUOTE=ChipN] Gas mileage seems to be slightly less than "real" gas based on trips to places where I can get it (although the EPA disputes this). QUOTE]
Sure, your mileage is less. It takes approx. 30% more alcohol to equal the power output of a given amount of gasoline. It's another attempt by the Government to reduce fossil fuel use and keep the corn farmers happy.
Greetings from Waupaca Cliff ! I have'nt heard of any problems (nor have I had any) from anyone up here. I use BP & knock on wood, no trouble. Not to change the subject, but who installed the exhaust system on your coupe ?
I don't think you will be able to avoid it for long. 10% Ethanol is all we have around here However, it does not seem to be a problem, more of a problem with the other additives or lack of them...
This is weird. I just returned from a trip to FLA. and I had fuel gauge problems during the trip. Now that I am back and can get Sunoco 94 the problems have gone away. If it is fuel typr related it baffles me totally .
Patrick-
Corvette Sports in Sheboygan installed my headers. They did a good job. http://www.corvettesports.com/ They even have some pictures of my install on their web site.
Exhaust was done at a local muffler shop when I lived in Cincinnati, OH for about $50.
Ethanol is a solvent and will dissolve old gunk from your fuel tank, but the fuel filter should catch it.
People running E85 in non multi-fuel cars frequently have to change the fuel filter the first few tankfulls, but it is 85% Ethanol not E10 and not recommended anyway.
Thanks, maybe that's what I heard as a kid...that it clogged up the fuel filter. I guess I'll have to live with it, but I thought I saw a couple stations in town that said 100% real gas. I'll have to do some more detective work to see if I can find the real thing in town.
ROJO99 -- that's exactly what happened to me. Anything but Sunoco 94 seems to cause issues for me.
I'm going from memory here but I had read that GM used silver in the contruction of the sending unit in the tank and it reacts with either additives or detergents found in low octane fuels. Before I saw this, I was going to replace the sending unit but found stories from other owners that had replaced the sender multiple times only to have the trouble come back.
GM, Ford and Toyota have published a list of approved gasolines, it includes Chevron and Shell but not BP or Mobil. The additive level or lack of additives in the gas can cause the fuel guage problem. I have had the problem occaisionally when I could not get good gas. While I have not had the problem with Mobil, others have said it can happen
