anti skid system
Old Aug 7, 2005 | 05:49 AM
Boeingman's Avatar
Boeingman
Default anti skid system
Since I never had a car besides my present vette that has had antiskid brakes, I don't really know how the brakes feel when the anti skid is activating.
If I give the brakes a good push so as to decelrate at a high rate I sometimes feel my brake pedal pulsate. This pulsating is not like the kind one feels when a brake rotor is warped but is more mecahnical in nature. I can hear it also at the same time. It sounds mecanical like a tickatickatickaticka in very rapid succesion coming from my front end/break pedal.
The sound and feel of my brakes when I'm stoping this way is consitent with a valve opening and closing in rapid order. Is this my anti skid system activating? Is this the anti skid valve opening and closing as advertised when one is stoping quickly that the tires want to skid but that the anti skid system is doing its job normally?
Or might there be something worng with my car?
Thanks in advance.
Matt
Old Aug 7, 2005 | 08:03 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
That's your anti-lock brakes working. Nothing is wrong with your car.
jeff
Old Aug 7, 2005 | 10:21 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds to me like they are working fine. To test them out with out putting too much excessive strain on your tires, find a nice flat open road with out any traffic and nail the brakes when the road is wet!
You need to expirrence how they work and get comfortable with them so that when you REALLY need them you wont panic.
The real sweet part about ANTI-LOCK and Active Handling (if you have it) is being able to steer around an obsticle while you have your foot mashed to the floor on the brakes!
Throw a cone in the middle of an empty parking lot, run at it at 40 mph and at the last second cram on the brakes and steer around it!! It works like a champ!!
If you practice this ahead of time, when a real situation arises, you will come out of it smelling like a rose!!
BC
Old Aug 7, 2005 | 09:31 PM
Boeingman's Avatar
Boeingman
Thanks for the info on the brakes. I agree their's probably nothing wrong with my brakes.
Also, sorry for the wrong nomenclature as to my refering to the "anti skid sytem" instead of the "anti lock sytem". I happen to be in the aviation career field and this type of system is refered to as the anti skid sytem. Anti Skid/Anti Lock both work in the same manner to accomplish the exact same thing. However, in an aircraft you don't feel nor do you hear the system operating through the brakes. ....I know, I know who cares; we're talking vettes here not planes so I'll shut up.....
Anyway thanks again for the good info.
Matt
Old Aug 7, 2005 | 10:31 PM
Mike Mercury's Avatar
Mike Mercury
yep. I periodically test my anti-locks if in loose gravel - on a wet or snowy road. I always check to see if someone is behind me first.
getting aquainted with ones car is a good thing
To anti skid system
