Will Lowering Damage...
Thanks in advance!!
Anything lower than about 8/10th lower than the stock adjustments allow (w/o cutting bushings, etc.) is a compromise between looks and performance.
IMHO, these cars need to perform first, look cool while doing so is a close second, but never at the expense of performance.
To have the car that low w/o any penalties, go with a coil-over conversion. And if you haven't already done so, come on over and join the "Posse".
: Yuck!I myself disagree with the "performance first" theory. Although probably correct, I don't drive my car at LeMans and believe "stock" Vettes look like 4x4's with all that space between the tire and fender. So I go the
route first. Personal preference...I'm no expert, but my car's been slammed a long time now and haven't had any other real problems. It's all worth it to me when I have to look up to see kids in their rice burner's. I like low.
I've got Bilsteins now. I also track the car, so have not slammed it to maintain as optimal as possible (based on my limited knowledge) suspension performance. You can see in the sig there's not much clearance in corners as is. That was starting with 2+ fingers in front and 3+ fingers in back. I've sinced raised it a touch.
(theoratically)
Thanks!!!!!!!!!!!!!!!!
Lowering your suspension does lower your CG (woohoo) but it can lower your roll-center much more (doh!). The greater the distance of the roll center to the center of gravity, the more tipsy the car feels.
This may sound stupid, but I actually have a big expensive RC car with an F1-like suspension (inboard shocks and all) with more adjustments than most cars... so I learned some of this from that... and GT4... so take anything I say with a grain of salt!
Where are the race pros!?Oh btw, one thing I am curious though is if anything on a mag-ride setup can be confused/messed-up by lowering.
So, lowering the car about 1.5 inches all the way around (as I have)......Have I increased my roll-center to an undesirable point?
Also,
I'm hearing you say that shock issues are not a real possibility...
Thanks for all the feedback...time to
http://www.stockcarproducts.com/pstech3.htm
I gave the instant roll center. So as you see you draw lines through the control arms to an intersecting point, then to the opposite middle tire, then where it crosses is the roll center height. I think this is more of a major concern on cars with a lot more suspension travel to start with than a Corvette... where people are lowering 2" or more.
BTW, so anyone figure out if the computer controlled mag-rid active shocks mind being lowered say 3/4 to an inch? I have no clue what sensors it uses to adjust the current in there. I have to get an alignment anyway, so wouldn't mind doing this first.
(theoratically)
I'd say you could come down about 1/2 to 3/4 of an inch, w/o any negative side effects. Any lower and you start trading performance for looks.
You give slammed a new meaning! Do you ever drive in areas with speed bumps or do you avoid?
The body is 3inches off the ground and the front air dam is 3/4 inch. I need it lower.
I have owned this car for 11 months and I've driven over 20,000 miles in it. I drive it everywhere - and there are speed humps at work - I go over them sideways. I have frame savers and rocker rails.
You learn to drive your car differently when it's slammed but I still drive it everywhere (as evidenced by my mileage).
I live in CT and I've been to KY for CF Cruise In 6 (2500 mile round trip) and to Canada. I drive it to work in RI almost every day.
EG
