Valve Spring recommendation
Old Sep 20, 2005 | 05:54 PM
24hr Z06's Avatar
24hr Z06
Default Valve Spring recommendation
Hopefully Ive got all this right..
I talked with my tuner and it looks like my spring in the #8 cylinder is toast, BUT its not that bad, and it looks like I will only need to replace the valve springs... I just wanted to know what kind of springs to throw in there? I plan on doing heads and a cam later on, but can't right now so I just want to put a good spring in there now so when I go to sell the heads I don't have any issues..
So which springs do you guess recommend I have installed for use with the stock cam? I don't mind spending a little more money as long as I get a good reliable spring..
Old Sep 20, 2005 | 06:02 PM
Av8ter's Avatar
Av8ter
Well since you have a stock cam and especially since youre planning on getting rid of the heads later, i would just throw a stock spring back on there. If someone else was to buy your stock heads and if they put a bigger cam in at the same time, they will have to get the springs that match that particular cam they have. Save your money now and apply it towards a double row timing chain or something when you do your heads and cam package later.
Old Sep 20, 2005 | 06:29 PM
24hr Z06's Avatar
24hr Z06
I would rather spend the extra money then have to worry about a spring going on me again as I am not 100% sure when I will be doing heads... Considering my springs only lasted 15,000miles (1 year october 1) I would rather not have to worry.. With that being said whats my best option?
Old Sep 20, 2005 | 06:41 PM
Av8ter's Avatar
Av8ter
Ok. Then I would probably go with the Comp Cams 26918 Springs. They are what I have and have been flawless. You can also use your existing retainers and keepers.
Old Sep 20, 2005 | 06:56 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Someone has a new set for sale in the parts section right now too..
Old Sep 20, 2005 | 08:54 PM
vettenuts's Avatar
vettenuts
For stock, I would actually go with the Comp 915's to keep the timing chain load down. You might also consider Cranes if going dual, but the 915's should be a good setup.
Old Sep 20, 2005 | 09:55 PM
Silver98's Avatar
Silver98
Hey, this is NOT a challenge, but I have not learned about this. Would you please expalin how springs minimize the timing chain load? Valve train is not my strong suit, but I want to learn.
Thanks,
Joe
Old Sep 20, 2005 | 11:07 PM
bcseitz's Avatar
bcseitz
Thanks,
Joe
The timing chain drives the cam. The camshaft opens and closes the valves. The resistance the cam experiences is the amount of valve spring pressure. The higher the lift with a cam, the more spring pressure is required to insure the valves close on time, especially at the higher RPM,s.
Bob
To Valve Spring recommendation
