A C compressor
Old Dec 28, 2005 | 12:07 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by IM QUIKR
Bill thanks much. I've read all the posts on this the search function would pull up and nobody mentioned an actual Vac amount or time frame. Here's what's up, I need to swap out an AC hose to install a TT and the system will be opened for only a few minutes. Just long enough to R&R the hose on the compressor. Then I'll need it recharged. What I've decided to do is have a shop empty it, I'll drive home and change the part and go back for a refill. I'll know to set some extra time aside to let them vac it out. By the time I buy or rent some equiptment and screw things up It'll end up costing so much more.
IQ
In all honesty, properly evacuating the system and only having it open for a few minutes is not too much of an issue. Just cover the ends of the hoses/fitings with plastic plugs, prep the new hose and O rings (the O rings need to be lubricated with mineral based 525 viscosity refrigerant oil. ) The service manual also states a WARNING as to NOT let any of the 525 get into the system!!! Maybe the AC shop that you are using will have some on hand for you to have to use as O ring lubricant. Once the hose is on and properky tightened, have the system serviced. It only takes 1.625 lbs of 134a to properly charge the system.
I would also recommend asking the shop to add a small amount of PAG refrigerant oil to the system.
Having the shop vacuum and recgarge the system is an EXCELLANT idea and shouldnt cost that much.
Good luck on your MODs
\BC
