Which rocker arms
Old Oct 2, 2005 | 08:28 PM
sams96's Avatar
sams96
Default Which rocker arms
Looking for a roller rocker that you just torque to 22lbs like the factory.
Old Oct 2, 2005 | 08:58 PM
Jeff Jeff's Avatar
Jeff Jeff
There is nothing wrong with the stock rockers. From what I have read, you wont gain anything from aftermarket rockers with the same ratio.
I would stick with stock unless you need adjustable ones or are looking for a higher ratio to give you more lift.
Old Oct 2, 2005 | 09:03 PM
vettenuts's Avatar
vettenuts
Curious why you don't want adjustable ones? I just installed the Cranes and they are great.
Old Oct 2, 2005 | 09:55 PM
FRCTony's Avatar
FRCTony
Look at these:
http://forums.corvetteforum.com/show...46&postcount=6
Old Nov 20, 2005 | 07:39 AM
davidfarmer's Avatar
davidfarmer
I run stockers on my 530hp engines that run to 7500rpm. Katechs says they are fine, and they run them on extreme duty off-shore boat engines.
If you're looking for increased lift ratio, I would go with adjustables to help prevent any mis-adjustment, just in case. It is NOT hard to adjust valves.
To Which rocker arms
