Michelin Pilot CUPS??????
Old Oct 8, 2005 | 02:20 AM
MUKAK's Avatar
MUKAK
Default Michelin Pilot CUPS??????
Has anyone ran CUPS on the street??
If so, how many street miles will I get out of them???
thanks
Old Oct 8, 2005 | 09:58 AM
joseph796's Avatar
joseph796
R compounds on the street = flat tires. You will pick-up every nail & screw on the road. Regarding street mileage, the max you will get is 5,000 miles on any R compound. Last, good luck if you are ever caught in the rain. I have Mich PS 2' and they are the best all-round tire I ever used. A close second would be the Bridgstone S0-3's.
Old Oct 8, 2005 | 11:06 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Bad Idea... if you want a very very stickey street tire go look at Nitto R2's. It's the R1 drag radial tread compound but still retains the stiffer sidewall for a goot race/street tire.
Old Oct 8, 2005 | 12:04 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Originally Posted by joseph796
R compounds on the street = flat tires. You will pick-up every nail & screw on the road. Regarding street mileage, the max you will get is 5,000 miles on any R compound. Last, good luck if you are ever caught in the rain. I have Mich PS 2' and they are the best all-round tire I ever used. A close second would be the Bridgstone S0-2's.
My friend has them on his 911 Carrera S. He got a flat inside the 1st month.
Ron
Old Oct 8, 2005 | 02:41 PM
AU N EGL's Avatar
AU N EGL
thanks
Rember R compounds are measued in Heat Cycles not miles. Yes the Cup tires get more Heat cycles then normal R compounds but not by much.
Just a wild guess here but 12-14 heat cycles at 75-100 a heat cycle ( if that )your looking 1200-1500 miles off a set of tires. Plus traction greatly decreases with each heat cycle.
Plus the very thin side walls and non belted soo any road clag and look out.
In the past I have Used Hoosier DOTs, Good Year G19s and now use Hoosier VRLs. The first Hoosiers I got 4 weekends on the track or about 800 miles and the last weekend had no grip. The Good years was was 3 weekends and should have been two weekends.
The current set of Hoosiers, VRLs has one so so weekend on, but I think I can get two great weekends.
Figure 125 miles per day.
And ppl wonder why we buy scrubbs.
The difference between road tires and true road racing tires.
To Michelin Pilot CUPS??????
