Driver's side door lock
Old Nov 10, 2005 | 07:21 PM
ptiller's Avatar
ptiller
Thanks for the response.
Looking at the pic, I am guessing the other two relays are likely for the windows. Is it possible that all of them are the exact same type of relay?
If this is the case, six to seven bucks in parts can substantially rebuild a very expensive module. Wow!
Old Nov 13, 2005 | 08:03 AM
ptiller's Avatar
ptiller
My driver door will unlock, but both my driver and passenger doors will not lock ( also passenger window will not go up or down, luckily it is up ). When I hit the buttons ( door lock/unlock or window up/down on the door) I hear each relay actuate, but that is it. If I can hear the relays actuate (click), is my problem likely the relays and not a lock/unlock actuator or window motor?
Old Nov 13, 2005 | 12:37 PM
alanh's Avatar
alanh
ptiller, if you wnant to go to the trouble, take the door module circut board out of the case and plug all the circut plugs back into it. Check pin1, there should be 12V there, if there is, use a shorting wire to connect pin#1 COM and pin#3 NO (normally open). This is what happens inside the solenoid if it's working correctly. The lock should open or close depending on which relay you are bypassing. If the lock works, that's proof there is no electrical connection inside the relay. Just compare the pictures above of the bottom of the relay to the bottom of the circut board to locate the proper pin locations to do this test.
The window relay is different and the large relay may have both the up and down window functions in it. I haven't had one of thes apart to examine it. If someone wants to send me an old module, i'll take it apart and see what the relay's electrical connections are.
Old Nov 13, 2005 | 06:02 PM
michaelj_h's Avatar
michaelj_h
Default Wow, good stuff!
I have the same problem with my driver side door module, yet I haven't had the time to dig into it yet. I just happened to run across this thread. I assume this info. will save me a bunch of time.
Like was said before, This forum is great! Thanks to everyone who takes the time to share their knowledge and put up good pictures and explanations.
Old Nov 15, 2005 | 04:09 PM
604_c5's Avatar
604_c5
Default question!:)
After i take off the door panels, all i have to do is just unscrew the door module and take off the plugs and file them right?
and before i take off the circuit plugs, should i disconnect my car battery or it doesn't matter?
to this thread... they are charging me $480 only one side at dealership
Old Nov 17, 2005 | 06:53 PM
ptiller's Avatar
ptiller
It a tought call. For safety (more to protect the module), I would disconnect the battery. It does not take that long. These modules were designed for lowest cost and not for hot swapping.
Old Dec 7, 2005 | 08:20 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
this thread needs a bump
Old Dec 7, 2005 | 08:31 PM
GreekPT's Avatar
GreekPT
My 03 passenger door won't lock but will unlock, but I just bought it so the dealer will fix it. Great info though.
How does a newbie Vette owner and also Forum noooob "bookmark" or something similar, all these helpful threads for future reference?
Many thanks,
Phil
Old Dec 8, 2005 | 09:55 AM
SteveDoten's Avatar
SteveDoten
add them to your favorites if using msft IE
Old Dec 8, 2005 | 02:48 PM
white90conv's Avatar
white90conv
Thanks bindy and alanh. This thread was just in time for me - my driver door lock function has become eratic so I have the problem.
Old Dec 13, 2005 | 04:37 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
This needs to be submitted to tech-tips.
Old Dec 13, 2005 | 05:06 PM
edensknight's Avatar
edensknight
Originally Posted by bindy
I tore one open several months ago and filed the contacts, but unfortuantely that fix didn't last long. After finding the correct sized part, it was a no brainer to just replace it
Again, give ole Gene at the Karshop a call. Gene, will be able to hook you up with a used newer part far cheaper than any other dealer.
Old Dec 14, 2005 | 10:33 AM
  #33
oupike1757's Avatar
oupike1757
just did this fix on my 01 Z06. Works perfect now. I ordered a few new relays per BINDYS post and replaced the old ones.
Thanks CF once again.
Jeremy
Old Dec 14, 2005 | 10:44 AM
  #34
elric's Avatar
elric
Many thanks,
Phil
Mine is the exact opposite. My passenger door with not unlock with the power, but will lock. You can hear it try, but it sounds like it is just sticking. I'll probably have to remove the panel and see wtf is up but I have been too lazy
Old Dec 17, 2005 | 03:10 AM
  #35
atz06's Avatar
atz06
Originally Posted by ob1vette
My driver side door lock only works manually. It will unlock with remote fob and by pressing unlock button on door. the dealer wants $600.00 to replace "door module". 99 roaster
Same here on my 2003 Z06. I took it to the dealer yesterday and they replaced both the left and right door module under warranty
Old Dec 30, 2005 | 02:06 PM
  #36
MrLeadFoot's Avatar
MrLeadFoot
Alanh and bindy, you guys are da bomb, as they say!
Thanks so much for taking the time to document this. I just ordered by relays from Digi-Key, and hope to be able to rely on my locks once again.
Kudos to you!
Old Dec 30, 2005 | 08:30 PM
  #37
TroyPyles's Avatar
TroyPyles
Suggest you check your codes first to make sure you know what's wrong.
BTW sometimes mine stops working for a day and then starts up again. Some sort of gremlin.
To Driver's side door lock
Old Dec 30, 2005 | 11:57 PM
  #38
MrLeadFoot's Avatar
MrLeadFoot
If the relay contacts are burnt, then I'm pretty sure there won't be any codes. I don't see any codes thrown at all. At first, like most of us that have had these issues, the problem was intermittent. Unfortunately, I would venture to guess that as time goes on, your "gremlins" will probably reveal themselves as a worn out relay, too.
Old Jan 2, 2006 | 01:20 PM
  #39
MrLeadFoot's Avatar
MrLeadFoot
How can you tell by looking which relay is the unlocker and which is the locker?
My driver's door does not lock, and my passenger does not unlock. I ordered 4 new relays (2 as backups), but it sure would be nice to know which ones to replace, does that make sense?
Old Jan 2, 2006 | 02:48 PM
  #40
RonJ's Avatar
RonJ
I'd like to know what relays you ordered. According to an earlier posting, JSM1-12V-4 is needed.
I have the DCM circuit board from my 01 sitting in front of me right now, the number on the relays is JSM1E-12V-5-H15
I can't find out if these two numbers are interchangeable or not.
RonJ ...
