Check Engine Light :(
Old Oct 26, 2005 | 12:29 PM
Tommyz's Avatar
Tommyz
Default Check Engine Light :(
I start the car up a couple days ago and the light comes on. At first, no noticeable issues. The next day, the light is still on and I started to feel hesitations in the engine right after startup. After it warmed up it was fine. The following day, fine at startup, but hesitating when warm. The codes that I'm seeing are:
PCM P0171 H/C - Fuel Trim System Lean bank 1-B
PCM P0174 H/C - Fuel Trim System Lean bank 2-B
The funny thing is, a couple of days after I got fuel at my local BP station, they started to tear it down and are in the process of replacing their underground fuel tanks...hmmmm?
My car is a 2000 coupe MN6 with 57K miles.
I have yet to replace the fuel filter, can that be a possible cause?
Any suggestions??
Old Oct 26, 2005 | 04:50 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would check the air bridge and MAF connections for an air leak! Check everything from the TB to the air filter. Make sure that the plastic accordian tube or plastic air bridge are NOT deformed (crimped) due to the hose clamps being too tight!.
Reset the codes and see what happens.
BC
Old Oct 26, 2005 | 07:17 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
Make sure you spin your gas cap real good. Still the number one reason for check engine light.
Ron
Old Oct 27, 2005 | 09:29 AM
Tommyz's Avatar
Tommyz
I'll try your suggestions... Thanks...
Old Oct 27, 2005 | 12:03 PM
TESTOSTERONE C6-R's Avatar
TESTOSTERONE C6-R
At 57k I would change my fuel filter...I change mine at 55k and it was dirty.
To Check Engine Light :(
