Compression ratio with Mongoose heads
Old Dec 7, 2005 | 03:48 PM
427 ls1 C5's Avatar
427 ls1 C5
Default Compression ratio with Mongoose heads
Does anyone know what the static compression ratio for my motor would be with Diamond flat top piston (4.125 bore) and AFR 225cc Mongoose heads with 66cc combustion chambers. I've e-mailed AFR but haven't heard back. I'm changing from Patriot heads and any advice on the AFR's would be helpful. Thanks.
Old Dec 7, 2005 | 04:42 PM
vettenuts's Avatar
vettenuts
I would contact Tony Mamo directly. He is very knowledgable and gets back to you very quickly. He has answered all the questions I have asked on AFR heads. He also is on the LS1tech.com forum as well.
Old Dec 7, 2005 | 05:03 PM
427 ls1 C5's Avatar
427 ls1 C5
Thanks for the tip.
Old Dec 7, 2005 | 05:10 PM
mdhmi's Avatar
mdhmi
http://www.angelfire.com/fl/procrastination/motor.html
That might help.
Mark
Old Dec 7, 2005 | 06:35 PM
kumar75150's Avatar
kumar75150
If its a flat top piston, you should be around 12.25:1 assuming a .054 head gasket with zero deck height.
THats way too much compression to run on pump gas unless u are running a gigantic cam and even then, I doubt it.
Old Dec 7, 2005 | 09:15 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
http://www.c5frc.com/calculators/Com...Calculator.htm
Old Dec 8, 2005 | 03:53 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
both things
To Compression ratio with Mongoose heads
