I have a wobbling balancer and want to replace it. I suppose I'll go ahead and put on an underdrive pulley, but I have a few questions. First, does anyone know if I can buy one from a store in the Dallas area, or do I have to order/ship it. Second, do I really want to do this myself or let a pro do it? I'm not a complete idiot with a wrench, but it sounds like the original is a pain to remove, and I don't know what's involved in pinning or keying the new one. Thanks.
The original is not pinned, so if you just do a one for one replacement you won't need to pin it. An underdrive can yield a few HP if you want to go that route. I went with the ATI, which is rebuildable as well. The hub is already keyed to receive a pin and they have a pin kit that is all inclusive and easy to use.
You will need to remove the power steering rack to get at it. If you need to change the coolant, you might also consider dropping out the water pump so all the coolant dumps and you have better access. Take a look at the cam swap on LS1Howto.com to see what is involved.
I'm not sure if there's a place local that stocks them, I had to order one from MTI because ThunderRacing was out at the time. Texas Speed and Performance had a different brand of one on sale not too long ago.
Pinning and Keying is a requirement for a car with a supercharger, not N/A.
If there's a two piece timing cover on the market that doesn't leak, you might think about adding this while you have to take out the steering to cut down on labor of a cam change, I wish I would have.
It is no easy task. Getting the pulley off is a pain, but not too bad. Putting the new pulley on is the hardest part. You have to put 250 ft/lbs to seat the pulley, then you need to use a new bolt and torque it down, then angle torque it. Quite a few people mess this step up, stripping crank threads, etc.
GM makes a tool to seat the pulley (as opposed to using the bolt and crank threads to do the work). And you will probably need a flywheel locking tool even if you have a 6 speed. 250 ft/lbs is a lot of torque and it can turn the wheels.
If you are going to do it yourself, I would look into pinning the crank. Many people (including me) have had the pulleys start to come off. Luckily I caught mine after the a/c belt shredded and before it spun off all the way.
What are my options for pinning the damper on the crank? Is the ATI kit the only thing out there? If so, does it work on non-ATI dampers? I understand pinning might be overkill for street use, but if I'm there already I'll go ahead and do it if it's not too much trouble/expense.
Has anyone had a bad experience with underdrive pulleys? Should I just stay stock diameter?
snap-on,....or craftsman sell a "gear puller" that will make this otherwise very difficult job a whole lot simpler and I would not put the stock part back on I mean there is just so much realy stuff out there! check all the "usual suspects" Jegs,.....ecklers,....or mid america!
I pinned mine, and I am not FI. I also went to the ARP bolt, which is installed with Moly lube so no fear of later removal. The ATI is a very high quality unit and is rebuildable. Others are available but the pin kit you use may also depend on if they are keyed. If they are not keyed, you will have to do an end pin if you decide to pin the balancer or you will have to get the balancer machined for a key if you use the ATI kit.
My pulley is starting to wobble so I guess I should be thinking about replacing the harmonic balanceron my 2001. I'm confused by the various sizes and types (internal or external weights) available. What do I need for a stock, daily driver? Seems that the OEM is no good, so why replace it with another OEM? Also, where do I get a flywheel lock for doing the job on an A4?
MOST engines used a zero balanced damper but check yours for weights (pressed in pins near the OD on the outer ring). If you have them they must be transferred to the new damper or it must be balanced the same way.
So IF you have them mark the relationship of the balancer to crank and your new one must be installed in this manner.
As far as OEM vs aftermarket (ATI), I don't ever remember anyone complaining they bought the best of anything!
Do key the crank even for street use! And a good 1/2" impact will remove your balancer bolt w/o a flywheel lock, and reinstall it with the same using red loctite to 150 ftlbs using a NEW bolt (I used ARP 12 point). And be done with the problem forever!
Tip: I bought some threaded stock from a fastner store with the right metric thread and cut it a couple inches longer then the stock bolt and using a thick flat washer and nut draw it down tight against the timing gear before installing the new bolt.
Thanks for the reply but 2 questions remain:
1. What size balancer do I need?
2. How do you get 150 ft-lbs without locking the flywheel?
If you have a M6 put it in gear and brake on.
It is 37# plus 140 degrees which is about 250lbs so you need a breaker bar and I use a jack handle as a 4' ext.
I have the Powerbond & ASP pulleys in stock! Our ground UPS will have it to you overnight so you can install it by Tuesday! Feel free to call or IM me if I can help!
1. Use the same dia. as stock 7.125"
2. Any good air 1/2" impact gun will easely get 150 ft-lbs and more when used on a 3/8-1/2" air line. I have 2 one is a CP-735 rated at 200 ft-lbs and a CP-740 rated at 250 ft-lbs. (I used to use them to crush the sleeve in GM 10 & 12 bolt pinions.)
had the shop do all the work as the steering rack has to come out...got a stock GM bolt to replace as well.
I believe it is 25% underdrive for the main belt and 10% for the AC. I have no issues with charging and the wabble is gone...so is the engine vibration I had with the old one...
Also had the shop pin the new install to make sure it never backs off..figure a shop to take 4 hours labor...
Unless you have some serious tools I would not recommend this for the do it yourselfer. I am rebuilding the engine in my 99 C5 and put the engine back in the car without putting the balancer back on first by mistake. You'll have to remove the rack and pinion in order to make the exchange. Also, I broke an impact socket getting the original bolt off, and to install it properly you'll need to come up with a long metric threaded rod.
Generally it means that its backing itself off the crank becuase it is not keyed or pinned...or it is starting to seperate (the rubber core part) as was the case with mine...it was not pretty! I can only imagine that letting it go would really cause a lot of damage...internal and external...
OK, I can see how an impact wrench could get the old one off but how do you do the 140 degree tightening without holding the flywheel? Also, are there any aftermarket balancers (better than OEM) that are not underdrive, i.e. stock size?
Put it in gear with the brake on. Trust me on this.
