FOB Training/Programming
Old Jan 7, 2006 | 06:44 PM
2KFRC5's Avatar
2KFRC5
Default FOB Training/Programming
Will the '97-'99 FOBs, part #10253839, work on a '00? And
will the '00 FOB, part #10432147, work on the '97-'99s?
Thanks-
Old Jan 7, 2006 | 07:28 PM
cheemsaf's Avatar
cheemsaf
Thanks-
I know a 97-99 will NOT work on a 2000...not sure about the others. Do a search on the forum for this...I know this has been answered before.
Old Jan 7, 2006 | 07:31 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
Nope. Three non-interchangeable versions. 97-99, 00, 01-04.
Take it easy.
Old Jan 7, 2006 | 11:30 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
From what I read the 2000 will work on 97-99
I just does not have the passive switch.
I have been thinking of changing the system to the 04 tire sensor and fob system. I just need to get the reciver and Tire sensors see if it works. JUst another thing on my todo list. It would save alot of cash when replacing tire sensors and key fobs.
Old Jan 8, 2006 | 11:54 AM
2KFRC5's Avatar
2KFRC5
I've read the same thing on the 2000, and as looking for a definitive answer both ways.
I plan on keeping this Vette forever, so your thoughts on changing the system seems like a good one when replacement time happens.
Thanks everyone.
Old Jan 8, 2006 | 12:33 PM
Chillin's Avatar
Chillin
Thanks-
My 2000 came with a 10253839. It works just fine Ihave tried the passive and it works also. Maybe it's just mine. I plan on ordering a second fob on Monday.
Rex
Old Jan 8, 2006 | 01:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are TWO arcitecher (SP?) RFA modules, FOB's and Tire Pressure sensors (TPS). 97 - 2000 & 2001 - 2004. If you have one, you can NOT use the other. It just wont work!!!!
The two TPS's are physicaly different in size and shape.
2001 and above C5 sensor.
97-2001 C5 sensor.
Mounted inside of an aftermarket rim that requires banding in place.
Bill C
Old Jan 8, 2006 | 04:09 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Bill
I know they are different
i thinking of swpping out whole system.
sensors recivers and fobs.
The harness is the same from 97-04
The recivers fobs and sensors are diferent.
Old Jan 10, 2006 | 01:16 AM
cheemsaf's Avatar
cheemsaf
I called GM on this...I have a 99, and was about to get a 00 FOB...they said, do not buy a 00 for 99 as it will not work. But then again, what do stealerships really know???
Old Jan 10, 2006 | 02:33 PM
FRCTony's Avatar
FRCTony
Bill
The fact that the harnesses are the same is encouraging.
PLEASE keep us informed on your progress!
I would do this in a second if I knew it would work
To FOB Training/Programming
