Reverse lights do not work??
Old Jan 13, 2006 | 03:46 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Reverse lights do not work??
My reverse lights come on when I unlock the car, but do not work when I put it in reverse. It is a Z06 car with a manual. Any suggestions where to start looking for the problem?
Old Jan 13, 2006 | 08:13 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The reverse switch on the tranny is where to start. I have had 2 god bad on prior 6 speeds. Very easy to change, just a little tight area
Old Jan 13, 2006 | 05:08 PM
redazz's Avatar
redazz
i had the same symptoms on my 99 6 spd and the switch was the problem
john
Old Jan 13, 2006 | 06:26 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
And if that doesn't fix it, sometimes the mini-fuse for this circuit blows as well, so after you replace the switch, check the fuse if they aren't working.
Old Jan 13, 2006 | 06:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep!! Tranny switch! Cost about 12 bucks at autozone!
BC
Old Jan 14, 2006 | 02:09 PM
screw991le's Avatar
screw991le
If you need pics from the service manual, let me know
Document ID# 217960
2000 Chevrolet/Geo Corvette
Backup Lamp Switch Replacement
Removal Procedure
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the intermediate exhaust pipe. Refer to Intermediate Pipe Replacement in Engine Exhaust.
Disconnect the backup lamp switch electrical connector.
Remove the backup lamp switch.
Installation Procedure
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the backup lamp switch. Tighten
Tighten the backup lamp switch to 20 N·m (15 lb ft).
Connect the backup lamp switch electrical connector.
Install the intermediate exhaust pipe. Refer to Intermediate Pipe Replacement in Engine Exhaust.
Old Jan 14, 2006 | 11:53 PM
Sigforty's Avatar
Sigforty
Okay, I replaced the switch and the mini relay, and the problem still is not fixed. Any other ideas?
Old Jan 15, 2006 | 09:45 AM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Did you manually check the switch operation and circuit? When the shifter goes in reverse, it pushes that ball on the switch in and completes the circuit. Unplug the switch and just jump the connector to make sure you have a complete circuit. If you do, there is a slight chance you didn't screw the switch in all the way. Don't go nuts though, overtightening can crack the case.
Old Jan 15, 2006 | 01:48 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You should also unplug the the connector from the switch and jumper inside the connector with a small piece of wire. That will tell you that the circuit is good or not.
BC
Old Jan 15, 2006 | 02:21 PM
Sigforty's Avatar
Sigforty
Thanks, I will try that now and see if I can track this thing down.
Old Jan 15, 2006 | 05:52 PM
dmoran1845's Avatar
dmoran1845
Super easy to replace.
To Reverse lights do not work??
