wideband install
Old Jan 13, 2006 | 12:17 PM
minytrker's Avatar
minytrker
Default wideband install
Will it hurt to drill a hole through the tunnel cover so I can run the plug through the cover. I plan on running the wires up through the shifter hole into the car. If I drill the whole and seal it back up that will save me from having to pull the exhaust and remove the cover just to run the wires.
Old Jan 13, 2006 | 12:34 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I'll be in the same boat soon. Interested in the same answer. My tunnel plate will be one of the ABS of steel or ABS of aluminum.
Bill C
Old Jan 13, 2006 | 05:29 PM
see5's Avatar
see5
Well, my header bung is far enough fwd that the ABS plate is a non issue?
Old Jan 13, 2006 | 08:36 PM
Patches's Avatar
Patches
A buddy and I just took a few screws out of each side of his tunnel plate to make room to push the WB sensor plug and cable through to the shifter access hole then replaced and torqued the screws. There was just enough clearance between the tunnel plate and frame for the cable. Very clean setup.
I routed mine through the front of the tunnel and into the shifter access hole. No muss, no fuss.
Old Jan 15, 2006 | 11:05 PM
minytrker's Avatar
minytrker
I installed it today. I ended up removing some of the bolts off the tunnel plate and was able to slide the wires and connector up through the shifter. I mounted my gauge, led, and reset button all in the ash tray so once I close the lid its all out of site.
Old Jan 16, 2006 | 08:28 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
A little late, but I used a 9/16"" bit through the tranny tunnel plate for the wires to come through with gromment. Then slotted my reinforcement plate to slide over the wiring for the wideband sensor (mounted where the cats should be).
Old Jan 16, 2006 | 06:28 PM
minytrker's Avatar
minytrker
Here is my gauge install.
Old Jan 16, 2006 | 08:11 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
looking good!!
Old Jan 16, 2006 | 09:09 PM
Mike Mercury's Avatar
Mike Mercury
same here.
here is where I installed my extra bung (just upstream of the pupcat):
I do not leave my WB O2 sensor in all the time - just for tuning, then I remove it and cap the bung.
I made a 1 foot sensor extension cable out of scrap sensor harness ends. With just one connector end attached, I drilled a 5/32 hole in the floorboard - near the tunnel and poked the wire through to the interior. Then I soldered on the other (inside) connector end. The 1 foot extension stays installed (obviously). The inside end is tucked up inside the center console and is easily pulled out when needed. The outside end is wire-tied up - out of the way - and the connector end is sealed in a plastic bag for protection
Old Feb 6, 2006 | 08:05 PM
IM QUIKR's Avatar
IM QUIKR
Is it feasible to leave the O2 sensor in place and use a toggle switch to turn the guage/sensor on and off. It burns out from constant use, right? Or is it just because of it's placement. It seems like a PITA to put it in and take it out each time.
Old Feb 6, 2006 | 08:56 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
It is my understanding that if you leave the sensor installed in the bung then you want it to come on when the engince runs otherwise there is the potential for moisture to accumulate on the sensor and ruin it. Otherwise it should be removed from the exhaust when not in use.
I too think it would be a real pain to install and remove every time you wanted to do some tuning. So I plan to leave mine in and take a chance.
To wideband install
