Problem with 4.10's
I have the DTE 4.10's. I read a post by them a while back where they recommend adding a bottle of friction modifier even if the fluid already has some added. I am running Redline 75w90 with the limited slip additive premixed.
Anyone else have this issue? I am going to try adding some more friction modifier to see if it helps. I need new tires soon and would like them to wear even.
DTE clearly states that you are to use the Redline fluid, and ONLY the Redline fluid, AND one bottle of GM additive, PERIOD. DTE uses stiffer springs in the clutch packs, and you need the additional friction modifier.
Don't make trouble for yourself by second-guessing the experts.
Has anyone else had a similar issue? Has adding some additional friction modifier (above what comes premixed with redline) fix the problem?
Did you purchase the differential from a dealer?
Did a third-party installer put the differential in your car for you?
Did they put the recommended lubricants and FMA we provided with your differential in it's entirety?
Did they give you your differential packett that is included with the differential?
We've found that many dealers or third-party installers often neglect to give their customers any of our documentation we include with our differentials that is actually meant for the end-user customer in the first place~ which is not the way it should be done....
If you need a new copy of these documents or if you need any of our newest pre-blended Redline 75w/140 we now use for greater differential heat protection, give us a call or send an email and we'll get you taken care of.
Id like to get gears, but im concerned.
DTE, where are the problem areas your seeing.
2) once a DTE rear is installed how often to I need to change the fluid
3) what's the break in method for the rears
4) what's the maintaince like for the DTE rear?
5) why is it so differant from the stock rear. (as far as pooping out )
6) what mistakes do you see owners doing (like someone needing stage II but buying stage I)
please help me be confident in your product.
Are the posi clutch springs in your units much stronger than stock?
If yes..why?
Is higher posi clutch pack spring force always the best thing for an AutoXer / Roads Course Car?
I can understand the up side to a super tight posi unit for a drag racer...
If you look closely at the level of attention to build details, the exclusivity of our in-house engineered HD components and our proprietary building techniques, you'll soon see where the major differences are. Addtionally, we have been the *ONLY* Corvette IRS differential builder to perfect the 2-series conversions for HP use, without sacrificing durability in any way. We've got dealers, distributors and users of our HD differentials and driveline products all over the world and if they didn't perform as well as we state, we would not be as succesful with this endeavor as we are today. The quality of the product speaks for us and always has...
DTE
I thought it would be easier to post stuff on here rather than through the US snail mail for information. Just could help with more sales. There's a bunch of people that are interested in your rears ( im not sure I like the way that sounds)
I will send you an email requesting the documents.
My question for you now is will the problem I am experiencing go away if I switch to the proper fluid mixture? If so, what is the mixture? Or do you think the problem indicates the differential is broken?
Posi Clutch Pack Spring Force?
If the spring force depends on the applications and the power of the car.
And you’ve build quite a number of differentials for road racers, auto-x'ers and driving school instructors and they are very pleased with the performance of our products.
Do I have to contact you and special order my diff for AutoX and HPDE?
Ok thanks
that's the answer I was looking for
