Best Underdrive Pully
Old Jan 24, 2006 | 06:16 AM
freemanjc's Avatar
freemanjc
Default Best Underdrive Pully
Can anyone recommend a top notch under drive pulley with belts! Also, will the pulley affect my after market stereo and amplifiers/
R/
Free
Old Jan 24, 2006 | 06:20 AM
vettenuts's Avatar
vettenuts
The best one out there is the ATI, but it only comes in a 10% under drive. They were working on a 25%, but I was told at Carlisle last year some of their tech people didn't want to do that as they felt it would comprimise their ability to dampen the crankshaft harmonics, which is the real job the dampener has to do. The hub is also has a key machined into the hub so you can easily pin the crank with their pinning kit.
Old Jan 24, 2006 | 06:28 AM
freemanjc's Avatar
freemanjc
vettnuts,
Do you have alink where I can get it from. Alos, do I need to get an belt as well?
R/
Free!
Old Jan 24, 2006 | 09:39 AM
TheRooster's Avatar
TheRooster
Asp.
Old Jan 24, 2006 | 09:53 AM
SynistrC5's Avatar
SynistrC5
The ATI is definetly the most serious race balancer however if you are looking for more than a 10% underdrive check out out the new SLP balancer
http://www.thunderracing.com/catalog...vid=7&pcid=111
SLP has stepped up the bar with their underdrive pulley/balancer combo's last year and is doing very well.
Old Jan 24, 2006 | 11:49 AM
vettenuts's Avatar
vettenuts
Originally Posted by freemanjc
vettnuts,
R/
Free!
ATI Super Dampers
I have the belt part numbers at home.
Old Jan 24, 2006 | 01:43 PM
George V's Avatar
George V
Has anyone ever pinned an ASP
Old Jan 24, 2006 | 02:02 PM
vettenuts's Avatar
vettenuts
George,
To avoid the end pinning, I would see if a machine shop can cut a keyway in the length of the hub. Should be an easy job. You might be able to call ATI and ask them for the dimensions of their keyway.
Old Jan 24, 2006 | 03:08 PM
George V's Avatar
George V
I could get that done but I will call them to see if it would weaken the hub, the ATI pinning kit actually makes a square keyway in the crank?
I guess the supercharging folks don’t use an ASP
Old Jan 24, 2006 | 03:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TTT
Old Jan 24, 2006 | 03:48 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Sure they do.. They are certified I believe. Anyway, you can pin any damper with a kit (I pinned my ASP simply to avoid the whole 240 ft-lbs of TQ nonsense).
Old Jan 24, 2006 | 04:09 PM
George V's Avatar
George V
What is the procedure; get the pulley keyed as vettenuts said, then us an ATI pinning kit for the crank?
Old Jan 24, 2006 | 06:45 PM
vettenuts's Avatar
vettenuts
No, actually it is just a drill and ream operation, but the pin that is used engaged the key on the hub. I like this setup better than the end drilled as I think removal and re-installation will be much easier if you have to ever go in again.
Here's the ATI crank pin kit.
And here it is on my motor (aluminum foil, etc. is to keep the chips out):
Old Jan 24, 2006 | 10:50 PM
George V's Avatar
George V
Bob
Its hard to see the pinning in the photo. So trying to visualize this process, there is basically a hole drilled straight down into the crank, and a keyway cut in the hub, how do the two keep this together?
Old Jan 25, 2006 | 01:02 AM
Dan_the_C5_Man
To be honest this whole "cutting of a keyway" is causing some confusion.
99% of the folks whom "pin their crank" simply install the damper, then bolt on the guiding plate that contains a hole drilled in it that sits exactly in the middle of where the edge of the crank and the inner edge of the pulley meet. You drill to a pre-determined depth, insert a pin, put the crank bolt back on and you are done. Simple, eh?
Old Jan 25, 2006 | 11:27 AM
George V's Avatar
George V
Now that I understand
Old Jan 25, 2006 | 12:44 PM
vettenuts's Avatar
vettenuts
I have seen two methods of "pinning the crank" (that sound perverse )
The first is the way someone like Magnusen does it, where a fixture is bolted to the crank and a hole is drilled endwise to the crank snout with its center on the hub ID/crank snout OD. So the hole is split between the two mating parts. When I looked into this method, I wasn't sure how you would re-align the pin again if the damper had to be removed.
The second method is where the pin is put in at a 90* angle to the crank snout, which is the one I have above in the photo made bt ATI. The fixture bolts onto the snout and then a drill guide is first put into the fixture and a hole is drilled. Then the drill guide is removed and replaced with a ream guide, and the hole is reamed. The pin is then installed in the shaft. The ATI damper has a keyway milled into the ID of the hub, such that during installation the keyway slides over the pin. The crank bolt prevents the pin from falling into the inside of the crank snout.
To Best Underdrive Pully
Old Jan 25, 2006 | 04:28 PM
George V's Avatar
George V
Good explanation on both methods, thanks. It sounds like the guys with the ASP drill into the front, but your right, if you have to take the pulley off it will never go back on the same way.
Old Jan 25, 2006 | 04:42 PM
pdd000's Avatar
pdd000
ati super damper as said
Old Jan 25, 2006 | 04:43 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
Ati
