Caliper upgrade
C5 and C5 Z06 are the same except for the paint. Get some Wilwoods for the front from LGM and your done. Better than the new 06Z calipers.
Thanks for your suggestion. I was a Laguna again yesterday and a friend "cooked" his new OEM calipers in his C5. You mentioned Wilwoods. What about Brembo, Precision or StopTech. There are a lot to choose from. I want to get it right the first time. (Small money tree out back). - Steve
The calipers are the same but the do stretch with time. Changing out to new c5 calipers every two years at $180 ea is nothing, plus the new calipers brakets at $100.
For that money I would go with Baer or Brembo.
APRacing ( now owned by PBR ) and Alcon are great reacing brakes. Just need a BIG BIG WALET.
When some one cooks the stock corvette brake it seems the fist thing they want to do is put on a BBK.
How about a few other options that will work:
1- Learn a different braking style, break less and carry more moenteum. Turn of that darn AH as it WILL eat your rear brake pads up.
2- cooling, put on those DRM cooling ducts.
3- Castrol SRF brake fluid, or at least Motul or Superblue and BLEED the brakes before each day at the track.
4- Racing pads, not combo pads, there are really no racing AND street pads, it is racing OR street PERIOD.
5- Brakes only work when there is suffcient rubber on the road. Street tires wont stop as fast as slicks even the same width.
6- seasoned rotors. Ideally if we could get the 1.2" rotors with the PBR caliper that would be great, but they dont fit.
PPL complain about having to bleed brakes, I just find that quite time to slowly inspect my car, mm by mm to assure my saftey on the track.
