Best run flat tire
Old Feb 26, 2006 | 09:51 PM
texvette2's Avatar
texvette2
Default Best run flat tire
I've tried doing a search. I would be looking for the smoothest and
quietest ride. But no non run flats, dont want to deal with a flat.
cornering and the perfomance traits are not an issue
Old Feb 26, 2006 | 10:15 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
I am in a similar situation. I have to stick with runflats. When I do replace them, I will be going to Michelin Pilot Sport ZP(zero pressure). I believe there are many other members that have them, so they will be better to help with noise and traction. Good Luck
Old Feb 26, 2006 | 10:17 PM
REW89's Avatar
REW89
I like my Michelins. In my opinion the Michelins make much less road noise than comparible Goodyear's. Handling is great and ride is very smooth.
Bob
Old Feb 27, 2006 | 04:43 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
just got a set of michelins last week to replace the goodyears on our '02 coupe. they seem to ride better and are alot quieter.
Old Feb 27, 2006 | 04:50 PM
VolFan615's Avatar
VolFan615
Yellow C3/C5
St. Jude Donor '05-'06
I just ordered the new C6 runflats on some new 18/19" CCW wheels!
Old Feb 27, 2006 | 05:09 PM
FASST LN's Avatar
FASST LN
I went with the Kumho runflats and have been very happy with their performance and price.
I am not the original owner and so I don't know what it sounded like with the Goodyears on the car.
Old Feb 27, 2006 | 05:17 PM
Railfan's Avatar
Railfan
Which brands of run-flats cannot be repaired?
Old Feb 27, 2006 | 06:19 PM
vetteguy02's Avatar
vetteguy02
Michelin run flats are far superior to the Goodyear for noise and smoothest of ride. Both the Goodyear and the Michelin can be repaired. Firestone is one that cannot be repaired.
Old Feb 27, 2006 | 07:55 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
I've had a couple sets of Yokohama AVS Sports and been happy.
Old Feb 27, 2006 | 08:19 PM
dataporter's Avatar
dataporter
Michelin Zero Pressures When I shopped and bought them Costco had the best price (took a couple days to get them)
Old Feb 27, 2006 | 09:23 PM
texvette2's Avatar
texvette2
Thanks for the comments -- I went to discount tire and ordered the
michelins pilot sport zero pressure.
Old Feb 27, 2006 | 11:30 PM
jah13's Avatar
jah13
I got my Michelin Pilot Sport ZP(zero pressure) today from Costco. Wow, what a difference. I had the stock RunCraps on my C5 and the Good Years are no comparison. The Michelins are smooth, and much quieter. It feels like a different car.
Old Feb 28, 2006 | 09:33 AM
Road_runner's Avatar
Road_runner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Me too
Old Mar 1, 2006 | 02:03 AM
MeekRN's Avatar
MeekRN
also look at treadwear rating, if a tire costs 50% more but lasts 100% longer... also the harder the rubber the loger it lasta and the harder the ride...
Old Mar 1, 2006 | 08:45 PM
texvette2's Avatar
texvette2
the Goodyears have are the org. Just turned 19K. Look good
but just about 6 years old. Hard to believe had the 01 that long.
Guy at discount tire said they usually see about 30K but age it
might not hurt to go ahead replace them
Old Mar 2, 2006 | 10:39 AM
Westwopper's Avatar
Westwopper
Make sure when you have a runflat or any tire repaired, the dealer is patching the tire, not plugging it. Plugging the tire will ruin it.
The Pilot Sport A/S ZP's will work better than the other tires in cold weather due to different rubber compounds. Also, I believe they have a warranty that covers damage up to 12 months? and 25%? tread if the tire cannot be repaired.
Unfortunately, the treadwear ratings are some what meaningless. They are not useful to compare tires from different manufacturers.
Regards,
Tony
Old Mar 2, 2006 | 10:57 AM
RDVT4ME's Avatar
RDVT4ME
The michelin pilot sports also have a 2 year road hazard warranty.
To Best run flat tire
Old Mar 2, 2006 | 01:45 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
How so?
Old Mar 2, 2006 | 04:28 PM
Westwopper's Avatar
Westwopper
Originally Posted by JMc
How so?
Couple of reasons not to plug a tire:
1) the interior of the tire cannont be inspected for damage unless it is taken off the rim. If a nail goes in and "j" hooks, there can be damage to the innerliner that you won't know about. Since the inner liner of the tire acts as the tube (it is made of butyl), any damage to it can allow air to escape. Air escaping from the inside out is not good because it can cause seperations in the tire as it tries to escape. It will typically go to the weakest point, which due to flexing is most commonly the sidewall area. While I have not seen this in a car tire in a commercial tire with high airpressure, this is very common to see if a repair is done wrong or a bead is torn when mounting the tire.
2) The next problem is the plug itself will act like a wick. This will draw moisture into the tire. Moisture will help rust the belt package of your tire potentially leading to failure.
This may not happen every time, but you are not driving a Neon, your driving a 400hp car with pretty ridiculous performance potential. Plugs should be used if that is the only option to get home....
Tony
Old Mar 5, 2006 | 08:08 AM
03ELECTRON's Avatar
03ELECTRON
Default michelin pilots
why cant i find any info on the michelin pilot sport Zp not even on there web site all i see is the a/s
thanks
