Wipers won't shut off
1. the washers won't stop - so I disconnected the washer motor.
2. the wipers just started yesterday going on and off by themselves - so i pulled the fuse for now.
How hard is it to replace the board if that is the case?
Should I replace the whole motor or just the board?
I see motors for sale on e-bay from a parts (junkyard) salvage dealer for 50.00 - is this a good idea?
On my 98 Jimmy I found on a GMC forum to take the board off, re-soilder the connection where the harness (plug) attaches to the board. I also re adjusted the contacts that ride on the motor so they had a bit more tension. It has worked great ever since.....might try ?!?
I have pictures of the UDDERS that you need to clean! I will post them once I get home tonight! I know a couple of people who just cleaned the udders out and the wiper system returned to normal operation once the water drained out of the motor/control board. The correct fix is to remove the wiper arm mechanism and spray out the control board with contact cleaner or WD-40. Doing that fixed mine!
BC
I dont trust the forum to too many people, you and a few others help keep most of these guys out of trouble.
Bill aka ET
Bill aka ET
Bill
I took a week off and went to Cancun!
When I got back, I had too much to do to get on the forum.Thanks for the complments!
Will you be at ANY of the corvette functions this year??? Like the Cruise In, Carslile, Fun Fest ect??????? We have to get together one of these days!!!!
Here is the pictures of the udders that I promised
(thought I was just hijacking the thread didnt ya???
Here where the uders are:
Here is what they look like (there are three in there, trust me!!)
Here is what came out of mine!
Get them udders clean!!
Bill C
I took mine apart yesterday and got to the udders.....man was that area full of leaves and junk. I cleaned it all out. I also opened the wiper motor and cleaned the contacts with a little wd40.
Ok so now the wipers are working again with no problems.
But the washer pump still runs full speed when plugged in. Is the washer pump driven from the wiper control board or from the stalk on the steering column?
When I press the washer button on the column the wipers work like they are supposed to, but of course there is no fluid coming out due to the washer pump being disconnected.
I bought another pump thinking that was the problem, but it does the same thing...... any ideas?
Thanks,
Mike.
Bill,
Please help so that I can locate the third one.
Thanks,
Ed
Thanks,
Mike.
Had the same problem as the wiper switch had to be replaced which fixed it (was under extended warranty - would have been around $300 with labor).
I have a Hypertech program in the computer so I asked if I should remove it before they flash and was informed that it would be a good idea. So I did. When doing so the dash went nuts.....no gagues & all warning lights on......the dealer freaked and told me my car had MAJOR wiring problems.
I asked the "super tech" who was working on my car if he disconnected the battery yet.....and he said "no why?"
When he did all of the gagues and lights started working again.....WHEW!!!
Needless to say they told me that flashing the PCM would NOT fix any of my problems and to quit reading the forums.....LOL
They are telling me that I have an electircal short somewhere in the car and it would take a miracle to figure out.....
WHAT NOW?????
The wipers seem to work again lately with no issues, but my washer pump still runs full speed. I have disconnected it for now as I don't use it much here in Florida.....but it would be nice to have working again one day.
But on a side note my drivers door mirror has shorted as well.....the mirror turned yellow with a black spot on the side.......and now looks like the coating inside is melting..... The dealer wants 375.00 just for the glass as mine is heated and auto dimming.....
I found one online for 175.00....so I might pick that one up and paint it as it is the wrong color for me.
Any suggestions..........
More to follow:
Bill
NOooooo....
Auto Zone sells the original GM manufactured motor part for the same money with exchange. There is some time spent on install and once finished you don't want to do again
I'm going nuts with all of these wiring issues......something crazy is happening......
Here's the scoop! Straight out of the service manual! The PCM or BCM has NOTHING to do with the wipers or washer circuits! Trust me on this one!!!If you have resolved the issue of the wipers running on their own by cleaning the drains, that takes care of that problem. You state that the washers continuously run. The push button switch on the end of the wiper control stalk turns the pump on and also causes the wiper motor to run momentarily to remove the wash from the windshield. From your description of the washer running ALL THE TIME,, I would have to say that the windshield wiper switch is causing a problem. Check to see if that push button switch is stuck or making contact all the time. The washers running all the time indicate that the push button switch is stuck on! You have to fix that before I can say for sure that the wiper control board is bad!!!
If you want to diagnose the switch, and pull it off the steering column, I will give you the information that you will need to read with an ohm meter. Check for a PM and I will give you my phone number. Remove the switch and get an ohm meter and we will have at it!!
Bill
Mine just started doing this 2 days ago, but i couldnt find the fuse. Which fuse did you pull?
I'm having the same problem with the windshield washer pump as well
(wont turn off). any updates?
