EBCM replacement
Old Jul 15, 2016 | 10:02 PM
labidus's Avatar
labidus
I successfully repaired my EBCM today by soldering my relay!
I removed 5 of the 6 T20 screw from under the vette. it's more easy from under for sure! but how? I digged a little vette pit for changing my oil and do some other vette repair including this EBCM stuff!!
So if you have space where you can dig do that it will be more easy! I digged a hole of about 2 feet by 8feets by 1.5 foot...
Thank you!
I will take some photo of the pit tomorrow
Old Jul 17, 2016 | 11:06 AM
GCG's Avatar
GCG
Originally Posted by labidus
...I digged a little vette pit for changing my oil and do some other vette repair including this EBCM stuff!!
Thank you!
Pics???
Old Jul 18, 2016 | 06:55 PM
labidus's Avatar
labidus
Ok here the PIT, sorry my old jeep is on it need to do some repair on it like changing the oil pan
Old Nov 24, 2017 | 07:28 AM
JDMricist_03's Avatar
JDMricist_03
2003 C5Z
The only code I'm getting regarding the ABS/TCS/AH issue is C1242. The issue is intermittent and if I drive the car around for awhile it starts working again till I park the car and let it sit overnight. I sanded all the ground bolts in the engine bay as well as the ground rings on the ground wires so there should be no grounding issues. What are some other 'free' repairs that I could do before having to pull the EBCM and inspect the unit itself? Since it's intermittent I am hoping it's fixable because I have no money to be spending on anymore repairs right now. Any info that anyone could give me will really help me out. The issue is getting worse and worse and I'm afraid it will stop working altogether soon.
Old Nov 24, 2017 | 08:16 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
C1242 c h BPMV Pump Motor Ground Circuit Open
The issue deals with the small connector under the main EBTCM connector and the circuits that run the main BPMV Motor.
The very first thing that I would do would be to make sure that connector and the wiring is in good condition.
Next would be the internal EBTCM circuit/relay. DELPHI did a crappy job soldering the connections on the main board inside that module. Maybe all it needs is a solder joint repair. The relay that runs the motor could also be going bad. Its replaceable if you can solder and are handy.
Start with the easy stuff first.
BC
Old Nov 24, 2017 | 11:09 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is the schematic that deals with the EBTCM and that motor.
The ground that deals with the motor is G-103.
