ebay Header Install
Old Jul 1, 2006 | 06:24 PM
  #101
123sugey's Avatar
123sugey
Dig
FOR YOU GUYS CONSIDERING THESE HEADERS.....BUY THEM
I PUT 8,000 MILES AND 9 BOTTLES OF NITROUS THROUGH MINE AND NO PROBLEMS !!!!!!!!
Old Jul 1, 2006 | 07:38 PM
  #102
Warp Factor's Avatar
Warp Factor
I didn't read the whole thread.........
Anyone have before and after dyno numbers on these?
Old Jul 2, 2006 | 03:44 PM
  #103
oahuyahoo's Avatar
oahuyahoo
Originally Posted by Ikester
Pay a few hundred dollars more and they bolt right up...no hassle..done!
Will not trade my dynatechs for anything.
Old Jul 8, 2006 | 02:24 AM
  #104
RichAshley-Black99's Avatar
RichAshley-Black99
Well I finally got aroung to installing these wasnt too bad....was fun
I didnt have to relocate the o2 sensors, cleared frame with no problems
But do make sure to put 02''s in prior to bolting up headers, theres not a lot of room it could be done but still do before hand
Kept my stock cats for now just had to do a little cutting
had to remove drvr side valve cover, headers wouldnt clear
had to remove steering shaft, no biggie
Passenger side header slide rite in from top
EGR pipes were not threaded used some nuts on backside for that
Tabs that connct to bell housing underneath are about 1 inch to far back Ive fabed up a new bracket to put in place..
Drvr side header about 5/8 lower than pass side
Other then that the fit is good Im satisfied with them
I think total cost was under $400 . I dont want to speak to soon but no codes yet "knock on wood" heres a few pics from the install[
Old Jul 8, 2006 | 02:31 AM
  #105
RichAshley-Black99
More pics
I still need to cut some of the clamp bolts ends off in the morning so they dont scrap
Old Jul 10, 2006 | 09:32 PM
  #106
indy300's Avatar
indy300
What are solutions to the hole alignment issue at the bell housing? Are there any weld-free fixes?
Old Jul 11, 2006 | 06:35 PM
  #107
suicide king's Avatar
suicide king
Default headers
Originally Posted by AshleyRL-Black99
More pics
What size pipe and clamps do you use to connect to your H pipe?
Old Jul 11, 2006 | 06:45 PM
  #108
sugarwolf's Avatar
sugarwolf
Dude the bracket needs to be taken off and flipped around thats how u fix it. On my freinds vette he used the same headers and just needed to flip the braket around..
Old Jul 11, 2006 | 10:20 PM
  #109
cruisemon's Avatar
cruisemon
It seems incredible that it would be something that simple but that's all that is needed. The headers will need to be squeezed in no more than 1/8th or so to let the mounting bolt slide into place.
GOOD EYE!
Charlie
Old Jul 13, 2006 | 05:05 PM
  #110
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
That looks like a very low cost way to mate them to the stock midsection!
So now we now how to solve the tabs being off, many have found it unnecessary to move the O2 bungs and the above method of mating them to the stock exhaust makes this a slam dunk long tube solution for ~$500.
Old Jul 13, 2006 | 05:46 PM
  #111
JJWVETTE's Avatar
JJWVETTE
Very clean install
Old Jul 21, 2006 | 12:07 PM
  #112
RichAshley-Black99
Well I had no codes to begin with, I just finished a 1600 mile road trip to Missouri and I got codes, and also I need to take it to a shop Ive got an exhaust leak so I might have to have some collectors welded on, Im pretty sure the leak is on the inlet to the cats.........I used 3id/3id sections to connect the two pipes, and 3 inch stainless clamps... might just wait and order some high flows. The car really pulls from 3 grand up though. ill post updates, also I fabed up a new bracket to attach the headers to the bell housing just havnt put it in though
Rich
Old Jul 21, 2006 | 03:01 PM
  #113
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Try Torctite 3" wide stainless stepped band clamps. I used them and they seem to seal very well.
Old Jul 21, 2006 | 10:44 PM
  #114
RichAshley-Black99
I had originaly intended to use those but with my time constraint of moving .......
Old Jul 21, 2006 | 11:59 PM
  #115
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
So far I love mine. Hell of alot better then spending a grand or more.
Old Jul 22, 2006 | 01:05 AM
  #116
pawngod's Avatar
pawngod
me too!!
Old Jul 22, 2006 | 05:37 PM
  #117
00c5ken's Avatar
00c5ken
Default dyno
Anybody dyno'd them yet???
To ebay Header Install
Old Jul 23, 2006 | 03:04 PM
  #118
David426's Avatar
David426
Some numbers would be great. I've seen numbers as high as 30 rwhp for LG longtubes. I don't want to spent that kind of $$$$. If i can get close to that with these headers, it will be worth it.
Old Jul 25, 2006 | 09:27 PM
  #119
byte_me's Avatar
byte_me
any more installs of these headers??
Old Jul 25, 2006 | 10:57 PM
  #120
htvette's Avatar
htvette
FYI, installed these headers about a month and no problems. All of a sudden my ac is blowing hot air. Took it to the dealer and they diagnose the ac line (I think it's the low pressure) is rubbing against the header causing a hole on the ac line. The dealer wants 600 for the repair (replace the ac line, evacuate and recharge freon). I plan on doing the repair myself. I remember the ac line was close but the insulator would have prevent this.
