stock air bridge vs halltech
Naturally, a less restrictive air filter will play a major role in air flow. Given....the stock C5 air box lid may be a little small, but is it smaller than the TB opening? Has anyone measured this to see?
Add more cubes, higher RPM's, etc then larger openings can aid.
Exactly.. Some folks think simply, that 100 highly-skilled GM engineers "can't be wrong". It's not that our arm-chair engineering is "superior" to theirs, it's that we have a different set of parameters to work within.This post kind of shoots a hole through the "Callaway intake is worth 500 bux because it includes a higher following replacement air bridge." theory.
The cutaway shown below illustrates the elimination of the air bridge. It shows a C6 Honker, but it's very similar to the C5 Honker.
Now, your exhausts are in line with other similarly constructed systems, even though you claim to outflow other competitiors in that area as well. So, why is the Honker is twice the price of quality competing kits when it clearly can NOT outperform the competition by double?
Sorry, I couldn't resist, 'cause if there's one thing that bugs me most, especially with cars of this caliber, is things not fitting right. If you can't make something that fits WELL, you have no business going after a market like this one.
This rule of diminishing returns applies to many performance upgrades, such as a supercharger. It costs more than 20 times the cost of a typical $250 intake system, but does not produce 20x the power (figuring a 12 RWHP increase from the intake).
Sometimes eeking out that last few HP requires many hours of design and testing - hence the fairly large jump in price. The other thing to consider as well is the fact that the Honker is 50 states legal. Getting approved by C.A.R.B. is not always easy or inexpensive.
Dave
I think you'll find that our Double-D exhaust systems, at $1,095, are at the higher end of the price spectrum also.
The Honker was designed for Corvette owners that want the best possible intake system. To us, that means the best engineered system with the most power increase, the most complete package for ease of installation, the most confidence that DTC's won't be triggered, the easiest to maintain, the best quality of the materials used for extended durability, and the best post-installation underhood appearance. Plus, for most C5 applications, the Honker is 50-state "emissions legal". C5 Honker development wasn't a cost-be-damned exercise, but cost/price was not the primary consideration. Performance was.
While airflow and power are the most important factors in choosing an intake system, they aren't the only factors. We haven't found an aftermarket system that outflows the Honker or makes more power in A-B C5 dyno testing. The difference is more than just an "eek". However, I think the Bang in "Bang for the Buck" means more than just power. It's ultimately Value, which in this case has to do with product design, quality of the materials used, the product construction, ease of maintenance, emissions compliance, its installed appearance. Basically, the things I mentioned above.
If someone is selecting an intake system with pricing as the primary determinant, clearly, the Callaway Honker would not be their choice. I'm admittedly biased, but if you consider the whole picture, then I think choosing Honker is a very smart move.
I wasn't necessarily implying what you commented about, but I guess it sounded that way, huh? Sorry for the confusion.
I own a software company, and I believe our products are top-notch, as well. But, just because we know that our products outperform the competition ("outperform" being a relative term, here), we keep our prices fairly competitive to even lesser products, simply because that's what the market for the genre bears.
Personally, I believe your Honker is priced too close to the OUTSIDE edge of the market, and might very well position you out of the market, as far as air intakes are concerned.
Yes, I understand that there were probably considerable costs involved in R&D and all the other stuff that goes along with bringing a product to market, but it almost seems like you're trying to pay for those costs with a relatively low number of sales. I would think it would be better to attain that particular revenue level by capturing the market than it is to try to attain that same level of revenue with a significantly lower number of sales.
Maybe it's just the marketing part of me that says it would make more sense to sell that product at $299, for example. Only a few of the benefits of such a strategic move I've listed below:
1) I believe your company would garner many more times the sales of Honkers you're probably seeing now, if the number of posts on this forum regarding people with Honkers is any indication of the ratio of Honkers to other intake kits.
2) Because an air intake kit is one of your relaively lower-priced items, a lower entry point would serve to allow consumers, who might not otherwise consider your products due to high prices, to sample a "taste" of what they can expect from ALL of your product line.
For example, if the Honker is indeed of the quality you've highly touted here (and I am by no means doubting your integrity), it is entirely possible that these new customers would then consider spending a bit more on your other products even though they might be at the upper end of the price spectrum, knowing that they can feel confident that the quality of ALL your products is worth the extra dollars, does that make sense?
3) While some might say that the people that already have say a Halltech Stinger, like me, or a Vortex Rammer, or whatever else have you are already off the market, that's not necessarily true. If the Honker really does outperform what I have, looks better, is easier to maintain, and makes forging CARB stickers from smog purposes a thing of the past, I would consider switching... but is it worth $500 to me? Heck, no! But, if the price was more attractive, say at the price point I mentioned above, that would enable you to actually steal market share. While that particular price would reduce your revenue per unit by 40%, wouldn't that be worth it if quintupled your current market share, or more (just a wild number, but you get my point)?
Sure, it would be worth it. Just look at how many people alone bought in on the WDP rotor extravaganza, or should I say "melee"? Yes, that whole deal turned into a fiasco for a lot of people, but the point is that just a simply post on this forum alone garnered that company hundreds of more sales than they anticipated. People who didn't even need new brakes bought them for later!
Of course, that company apparently could not fill all their orders, nor could their customer service handle the volume, but a company with good management would love to have that problem, wouldn't you agree?!
4) While this next benefit may not seem like one to you, I believe it is.
As far as I know, your Double-D exhaust is a relatively new system, as far as cat-backs are concerned. That's one of the reasons I shied away from it. I paid a little less than the Double-D exhaust for a competing system for several reasons.
More people seemed to buy the system I bought, so I felt more confident that the other manufacturer would take good care of me.
I was able to get more recommendations from other "users" of their products prior to making my decision
Undoubtedly due to their success in their particular market, the other company offered different configurations for its system, giving me more choices.
Sure, if you've followed any of my recent posts, you already know that I've had some fitment issues on the system I recently received, but as expected, the manufacturer has been very accomodating in helping me resolve my issue. While that in itself is great, that's not the point.
The point is that while your system may indeed have high QA, and all that, I didn't even consider your system because I know of very few people that even have your systems, and truthfully I was afraid to take a chance on getting an expensive "Version 1", you know what I mean?
Now, if I already had your "high-quality" Honker, let's say, I probably would've been more apt to consider your Double-D, even though maybe only a few people had it, simply because of my previous experience with the Honker. And, if you guys sold more exhausts, you might even be able to offer different configurations of them and capture even MORE people.
Callaway already has a good name, but to me, it has always meant "very expensive products meant only for racers, because those are the type of people willing to spend that kind of money". IMHO, you now have the perfect opportunity to significantly expand your market share and "take it to the streets". I bet you could rid the market of Vararams quite quickly (not that they're even a contender for Callaway), for starters, given all the bad raps they're currently getting.
Sincerely,
MrLeadFoot
I personally would get the Honker if you could show me data that it out performs my current setup. I have the Haltech Trap with fog shrouds cut open for air flow. If memory serves me right I think I paid almost $400 for that setup 2 years ago.
DH
if only you would have posted this info last year, you would have saved me 1 hour of aggrevation of removing the MAF off the stock bridge and onto my halltech stinger.
Sincerely,
MrLeadFoot
Before what I previously posted is ends up being considered a flame, I think I better qualify what I meant in that original post.
Sincerely,
MrLeadFoot
Perhaps I need to clarify as well.
The Honker Intake and Double-D Exhaust prices weren't established to intentionally be more expensive than other intakes. Working up from production cost, it just adds up that way. The fact is that it simply costs more to manufacture the Honker than it does to build some of the intakes you refer to. The Honker design is more complex so installation is easier. The main duct is more difficult to mold, resulting in a lot of rejected parts, because the duct's shape was designed to provide more flow than other systems. The filter element itself costs us more because it performs better. The list goes on. In order to reduce the Honker's price, we would have to compromise content or quality.
The suggestion that Callaway could charge $299. for the Honker if we wanted would suggest that we're artificially inflating our prices because we think we can get away with it, or basically price gouging. That's not true. When we were able to charge less for the C6 Honker ($390.) than for the C5 Honker ($490.), because the C6 version contains less components and is less expensive to build, we did so.
As for popularity, we are currently selling more Honkers than we can produce. Just ask any of our dealers how frequently we are out of stock (unfortunately). I don't mention this to suggest that the current prices are justified because of the product's high demand. I just don't want other readers to get the impression that Honker sales are poor because the product is overpriced, if that's indeed what you have suggested.
We really appreciate your opinion, Mr L. Your comments indicate that we have to work harder to communicate our products' value.
:cheers:
DH
