can someone help me with codes?!?!
Old Jun 3, 2006 | 11:35 AM
ILowNslowI's Avatar
ILowNslowI
Default can someone help me with codes?!?!
well ive taken my car in FOUR times for the same problem...now i just went & pulled the codes myself...
AO-LDCM...there was 3...B2282 H, B2284 H, U 1064 H
A1-RDCM...3 more...B 2283 H, B2285 H, U 1064 H
any help would be GREATLY appreciated ;-) thanx guys!!!!
Old Jun 3, 2006 | 12:50 PM
Dave68's Avatar
Dave68
http://www.stengel.net/diccodes.htm
Old Jun 3, 2006 | 01:10 PM
feeder82's Avatar
feeder82
mine threw similar codes when when I was having door look problems, theres a great easy fix here http://forums.corvetteforum.com/show...327&forum_id=1
Old Jun 3, 2006 | 02:47 PM
SFVetteman's Avatar
SFVetteman
The H indicates that the problem did occur but is gone....at least for now. Often, codes that come and go are the result of poor grounds. You might want to check the sticky at the top of the page by Bill Curlee for the location of the grounds involved and clean them.
Old Jun 4, 2006 | 11:54 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
AO ldcm - left door control module
b2282 battery #1 fault
b2284 battery #2 fault
u1064 loss of communications with bcm
the others are the same as the above except they are for the right door control module. try cleaning grounds and connectors. i had the same codes also. the windows did not work for a minute or two then worked fine since. the h after the code is for history and should be clear now.
Old Jun 4, 2006 | 01:00 PM
ILowNslowI's Avatar
ILowNslowI
kickass...thanx guys!!!
To can someone help me with codes?!?!
