Most cost effective air filter?
I'm assuming you're talking about an intake system, not just the air filter element.
Cost effective: Take the stock air box cover, cut out the center just inside of the reinforcement ribs (about 4" x 6"). Put in your favorite air filter element (Fram air filter actually isn't too bad, but no bling
). An alternative is the "tie wrap mod". This one just removes the air cover completely and tie wraps the filter in place. The only concern I have about this one is keeping the filter sealed on the sides.Best: A Procharger P1-SC set to five PSI
HTH, and have a good one,
Mike
The other question is by best do you mean highest level of filtration. or highest level of air flow through?
I am running the vortec on my car and I like it so far. You have to cut the shroud to use this system. Both are simple to install.
Cya
I would go with the Honker first.
Vararam: Brings cold air in through the fog light panel area to a panel-type filter. Owners have had good luck with system on the dragstrip, but plan on spending hours to install and a bit more to get everything lined up well. Downside: Eliminates engine bay-cooling air that would've come in from the fog light panels (Z06 or coupe/vert with opened-up panels), so the engine bay may end up being toastier, especially if you add headers later. $350-$400
Vortech Rammer: Brings cold air up from in front of the radiator and into an enclosed box. Its filter is quite a bit smaller than the Halltech Warhead or Blackwing unit. $250
Callaway Honker intake system: This one relocates the MAF so that it is just in front of the throttlebody. It directs cold air from underneath and costs about $400-$500. I believe this unit is 50 states legal (smogwise).
K&N FIPK: This is more of a semi-cold air system, as the cold air intake opening is more of a slit. Its filter endcaps are carbon fiber. However, it is configured similarly to the Halltech Stinger-R and is 50-states legal. $350
Warm air systems: (Easy installation)
Halltech Stinger-R: Not only contains the massive Warhead filter, but also includes a larger-than-stock airbridge and smooth throttlebody coupler. For $239.00 or less, this system represents one of the best bangs for the buck. Fortunately, for about $40, you can add cold air induction. See my procedure at http://www.conceptualpolymer.com/corvette_c5_corner.htm
Halltech Stinger SSM – 2001-2004 C5 only (new!): This intake system features an even larger filter than that of the Stinger-R, TRAP, and Blackwing. $400
Blackwing: Includes just a large filter, but an excellent one at that. Its cost is close to that of the Stinger.
Volant Twin Cone: This system gives you more open filter surface area than any stock box does and is well suited to an engine bay that gets cold air in from the fog light panels, as the filters are more or less in the air flow path. $265
2002+ Z06 airbox cover: A larger opening allows more air to be drawn in through the filter. Expect up to a 5 RWHP gain from this simple swap. $50
Zip-tie: An easy and inexpensive mod (eliminates the OEM box’s upper lid), but its sealing ability is questionable at best.
How good are they? My experience has shown that most will bump up RWHP by at least 10. The advantage of having cold air is that power will not be "dialed down" under normally hot underhood (and intake air) conditions. You could easily lose 10 HP with a warm air system after engine bay temps rise during slow-moving conditions. Cold air prevents this from happening.
I need opinions on the best air filter system for a stock c5?
Thanks SSS
A Zip tie mod works . I beat my brother by 5 lenghts at the Flashlight Drags in PA he has an 02. Cost is $1.50 and some people Dynowed 15 hp at the wheels. I know my seat o the pants was happy...
Nice low buck mod with the wall pocket. I have looked all over the hdwr stores for something that would work as a scoop with no luck. I should have shopped office depot
Good job!!
Good job!!
