code U1160 - I need help
Old Jun 18, 2006 | 02:17 PM
evasoukalova's Avatar
evasoukalova
Cruising
Default code U1160 - I need help
Hello, could somebody help me please, my Vette says code U1160.
Thank you Eva
Old Jun 18, 2006 | 03:26 PM
JonLT4CE's Avatar
JonLT4CE
Thank you Eva
From the manual:
DTC U1160 Loss of Communications with LDCM (Left Door Control Module).
Old Jun 19, 2006 | 01:00 AM
evasoukalova
Cruising
Originally Posted by JonLT4CE
From the manual:
Thank you very much. And please, do you have some electrical diagram from manual???Where could be a problem. Regards Eva
Old Jun 19, 2006 | 01:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Eva
I just posted this reply to another forum member and you may gain some help from the post.
Here is your own personal code reading web site:
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
[www.corvettedoctor.com
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.
Check out this post. You could be having some of the same pronlems:
http://forums.corvetteforum.com/show....php?t=1422394
U series codes mean that the module lost comms or power for a very short period of time. if the code is a HISTORY DTC, it normaly shouldnt be a problem. The door control modules are the first to be effected by power issues.
Are you seing any other codes??
Do the doors and windows work correctly when you see the code?
Bill
To code U1160 - I need help
