Spark plug removal
Old Jun 26, 2006 | 11:16 AM
Irish Whiskey's Avatar
Irish Whiskey
Default Spark plug removal
Apparently one of the back spark plugs on the C5-LS1 is difficult to remove. Is the "Sidewinder" wrench the one that is good for plug removal in this difficult area?
Old Jun 26, 2006 | 12:39 PM
rick7402's Avatar
rick7402
1st Gear
Don't waste your money on a sidewinder. The head of the ratchet is too big and the little handle at the end always turns being a general nusiance. I did my plugs using a flex head ratchet (proto, snapon also has one) and a universal spark plug socket ( a spark plug socket with a builtin universal at the end). I found the hardest part to be removing the plug wires. I didn't remove anthing extra. I just removed the red beauty covers. Disconected the wires from the coils. Heres the hard part. At each plug grab real tight on the boot and rotate one full turn to break loose. Then continue to rotate and pull. Its tough but works. I cound not find any tool to help on this part. Once the wires are off the rest is easy using the above tools. Hope this helps.
Old Jun 26, 2006 | 12:41 PM
vettenuts's Avatar
vettenuts
I bought the Snap-On socket that has the two ball joints built in, one of the best tools I have but it is a little pricey.
Old Jun 26, 2006 | 01:23 PM
keliente's Avatar
keliente
#8 on a vette looks like child's play to me, coming from an LS1 f-body
Old Jun 26, 2006 | 01:33 PM
litnrod's Avatar
litnrod
Default same problem
I just put each piece in separately, saved a trip to the store.
plug socket, extension, and then rachet...
plug wires, i was replacing mine anyway, so pop away. Unless you plan on reusing these.
Old Jun 26, 2006 | 02:05 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Double 90 degree joint or "knuckle" does the job with ease.
Old Jun 26, 2006 | 02:23 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
https://www.corvetteforum.com/techti...ID=7&TopicID=1
Old Jun 26, 2006 | 06:16 PM
Irish Whiskey
Thanks to all for the complete info on this.
Old Jun 26, 2006 | 09:46 PM
vette747's Avatar
vette747
I like when I have a lot of room.
Old Jun 27, 2006 | 11:23 AM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
Lisle, adjustable spark plug wire puller, part # 51750. About $ 25. 00. Lisle Corporation, Clarinda, Iowa, 51682. Snap - On uses this tool under a different # and calls it a Snap - On tool. It works great. I got mine at Pep Boy's. Good Luck !
To Spark plug removal
