what would cause
Old Jun 28, 2006 | 12:31 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default what would cause
the right had wheel gap between the wheel and fender to be 1/2" smaller than the left had side. Car is on a level surface and was lowered to the same height 4 years ago
Old Jun 28, 2006 | 12:48 PM
pro1955's Avatar
pro1955
Seems like it has to be a spring issue, does the rear set level?
Old Jun 28, 2006 | 12:51 PM
bozo4onion's Avatar
bozo4onion
I was going to post about this when I could get good pix. I got a new runcrap delivered. I saw it would arrive the following day so I removed the dead runcrap/wheel combo and left the car on a stand overnight. Anyway, tire remounted, wheel reinstalled and now the right side ( jacked side ) is almost 1 inch higher. Noticed it before I measured it so I don't think it was like this before. 2 months later still high.
Old Jun 28, 2006 | 12:53 PM
kactussjack's Avatar
kactussjack
poor body fitment. If the frame is level it has to be in the body panels. I have the same issue.
Old Jun 28, 2006 | 12:57 PM
Grumpy's Avatar
Grumpy
MONARTOR
rear sits level. just noticed it this morning. had no problems before..
Old Jun 28, 2006 | 01:02 PM
81c3's Avatar
81c3
Its entirely possible that when shipping by truck transport your particular car had fallen off the transport carrier!! Following the incident, it was pulled back inside at BG & 2 shop monkeys with BFH's simply "corrected" the problem by persuading the bent frame back into place.
Of course this is only possible, but not probable
sorry about that, I just couldnt help it.
Old Jun 28, 2006 | 05:14 PM
Grumpy's Avatar
Grumpy
MONARTOR
Old Jun 28, 2006 | 05:30 PM
yellow01's Avatar
yellow01
Measure the frame to ground. That's the important part. There's alot of variance in body panels.
Old Jun 28, 2006 | 08:30 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Possibly the end-link on the sway bar moved or the sway bar bushings are dry / sticking, causing it lever the car side to side? You could also check to make sure the spring hasn't de-laminated, or that something isn't up with the adjuster rubber pad or the shock itself.
Old Jun 28, 2006 | 09:02 PM
Grumpy's Avatar
Grumpy
MONARTOR
Old Jun 28, 2006 | 11:02 PM
ramairbrc's Avatar
ramairbrc
What would cause this? Unions! Like the United Auto Workers Union.
Old Jun 29, 2006 | 06:37 AM
Grumpy's Avatar
Grumpy
MONARTOR
nothing quite like a useful response..thanks for the nfo.
willig72's Avatar
willig72
Could it be the spring is starting to weaken on the right more then the left? Fact is that the right side take more abuse then the left due to crowns in the roads, debris etc. Could manufacture defect in spring starting to show. (one side being weaker the the other) Working with a fleet of over 10,000+ for over 20 years have seen these issues like this come up. Check and make sure the car is level (with a known good level) then start measuring very close and recording every point to point and you will find it somewhere. Hope this helps.
Old Jun 29, 2006 | 07:32 AM
dunbindun(tov)'s Avatar
dunbindun(tov)
Grumpy, you have entirely too much time on your hands.
DBD
To what would cause
