Engine Stalling upon clutch release - Help!
Old Jun 27, 2011 | 07:30 PM
SIXTY7SS's Avatar
SIXTY7SS
8VETTE7, thanks again for the rundown. On Saturday morning I was able to get the car ship shape.
I put a new battery in, put the key in and got a "service column lock" message and a "pull key wait 10 secs" along with the other service messages i knew were there (low fuel and low tire pressure)... I tested the 2mph shut off (it still cut-out). By the way I also checked... with he car off and no key in the ignition... the steering wheel was not locked (as you said)
from there I re-read your last few posts in this thread and a few others, reviewed & recorded the Codes in the DIC and cleared them out and then pulled fuses 25 and 29.
While under the passenger side footwell a modified relay harness didn't jump out at me so i went over to the drivers side knee panel to take stock.
I removed the panel and found the K-harness placed in line with the column lock. I removed it and installed the Column Lock Simulator and then put fuses 25 and 29 back in place. I started it up and everything seems set.
Guess I have an early 2001??
Anyways, thanks again, I know you have replied to a ton of these threads.
Now for my C6 ****. Good to have her back on the road its been a long 'winter' with just the pick-up truck.
Old Apr 15, 2017 | 11:02 PM
Jp1987's Avatar
Jp1987
1st Gear
Originally Posted by Bill Curlee
have you seen a message "PULL KEY--WAIT 10 SEC" or is your security light flashing?? You will normally see this problem with either of those messages. The security system tells the PCM to cut fuel if the cylinder lock doesnt see the correct resistor pellet in the key! Try your spare ignition key and see if it makes a difference!!
BC
Hey, I actually have this problem with my c5. Pull key wait 10 seconds msg is on along with column lock service. Car stalls as I try to accelerate off the clutch. How do I fix this problem. Why is it doing that?
Old Jun 3, 2017 | 03:37 PM
TJC5's Avatar
TJC5
3rd Gear
Originally Posted by SIXTY7SS
Like I said, I realize the thread was old before I replied. I figured it would be prudent to not start a new thread. I did search and read a number of threads before deciding to reply to this one (there are a couple others out there like this, but none with an answer to the problem) Good thing I did ask I got a possible answer! Now we have a thread with a start and possibly and end!
The battery is charging as we speak so fingers crossed that when i head out there i don't waste a trip.
a
I had exact same problem today, started fine, kept dying when releasing clutch. About a week ago battery was completely dead, charged battery and left on maintain for past week. I could rev engine so figured it was not fuel pump. Read suggestion to try other key and now working great. Thanks for the help!!!!saved me a tow bill to dealer and lots of aggravation
Old Jun 3, 2017 | 04:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by TJC5
a
It sounds like you are having a COLUMN LOCK sympton (i.e. 2 mph shut off). A word to the wise,,, Eventhough you THINK the other key solved the issue, I "STRONGLY" recommend that you purchase and install the LMC-5 which eliminates the issue that you are expierencing.
TRUST ME,,, I learned the difficult way many moons back when I had mY 98 Coupe.
If your car had the GM Recall, The column wont lock the steering column anymore BUT, the 2 MPH Shutoff will still strand you if the column lock system screws up.
Im sure 8VETTE7 will chime in and he is the resident COLUMN LOCK EXPERT.
Listen to what he tells you.
Bill
Old Jun 4, 2017 | 11:06 AM
TJC5's Avatar
TJC5
3rd Gear
Bill
Thanks so much for the advice. I bought my 2003 C5 two years ago so I am not sure about any recall. I assume I can ask a dealer about that. I admit I have very little knowledge of any thing mechanical. I will need to also ask the dealer what a LMC-5 is. Also just to add some clarity to my original post. The steering lock works just fine now, locks when I take key out and unlocks when key is in.
I am looking forward to any further advice or comment from you and or 8VETTE7.
Thanks again!
Old Jun 4, 2017 | 11:14 AM
CactusCat's Avatar
CactusCat
The dealer will probably not be aware of the LMC5 as its an aftermarket product that solves the problem permanently. Just look here and you'll see what it is and how it works.
http://www.complianceparts.com/lmc5ataglance.html It's one of the best $40 you'll spend.
Old Jun 4, 2017 | 12:08 PM
TJC5's Avatar
TJC5
3rd Gear
Thanks, I will order, hopefully I am smart enough to install it.
Old Jun 4, 2017 | 07:26 PM
CactusCat's Avatar
CactusCat
If you have even a single problem installing, just give them a call. Richard is one of the greatest service people to have ever sold a product on CF. I've read many stories where folks have called him and he walks them through the procedure. He's got your back...
Old Jun 5, 2017 | 12:42 AM
El original's Avatar
El original
Now I don't know if this applies. When I bought my Corvette it would only idle at 500 rpm and was hard to get rolling with out some serious throttle. The (purely accidental) fix was replacing a completely gummed up air filter. Replaced it and after 30 min. driving it idles at 800 rpm and additional throttle in not required...unless! Takes only seconds to check. Good luck.
