Engine Size Advantage - Disadvantage
Old Aug 3, 2006 | 02:30 PM
  #41
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Bob, I would spend some time really upgrading your suspension, brakes plus getting a 6 point cage before swapping engines. Just my 2 cents.
Stephen
Old Aug 3, 2006 | 02:31 PM
  #42
0EG@EnglandGreen
Supporting Tuner
L92 fuel rails look the same as the LS2 FRs
Old Aug 3, 2006 | 02:32 PM
  #43
0EG@EnglandGreen
Supporting Tuner
Originally Posted by Boob
I run a 383 LS1 through a completely stock ls1 TB making 486rwhp/458tq. Once I get a 90/90 setup it should be well over 500 rw. It was half the cost of most 402 builds which enabled me to get the clutch system and fuel system upgrades as well. IMO I don't think this little 383 is doing too bad considering it's making almost the same power as the 402 guys. In addition, it's also 100 lbs lighter than a 402 setup.
BTW, That Warhawk is pure sex!
LS1 (346, 383) & LS2 (364, 402) weigh the same...
Old Aug 3, 2006 | 02:40 PM
  #44
AU N EGL's Avatar
AU N EGL
isnt the L92 a TRUCK motor??
Old Aug 3, 2006 | 02:41 PM
  #45
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Stephen
EG - really I am not upgrading the engine until it dies. I just want to gather some information now so that hopefully I have time to figure out what will work best for me.
Regarding suspension I am in the middle of that too. I added T1 bars and new shocks this year, but I think I am going to a full T1 setup. I like the idea of coilovers, but not sold on them yet.
Brakes have been updated enough for now. After changing over to a racing pads I realized that the stock calipers are really good as long as you also change to a race brake fluid so until I get to the next level I am leaving them alone although I am adding cooling ducts.
and finally the roll cage is a must.
Old Aug 3, 2006 | 02:43 PM
  #46
0EG@EnglandGreen
Supporting Tuner
'07 Escalade
Old Aug 3, 2006 | 03:54 PM
  #47
0EG@EnglandGreen
Supporting Tuner
I think coilovers with the T1 sways and urethane bushings are as good as it gets.
Old Aug 3, 2006 | 04:24 PM
  #48
Boob's Avatar
Boob
Originally Posted by tlaselva
Wow, is a LS6 383 weight that much less than a LS2 402?
100lbs on the front of your car is quite a bit for a road racing Vette, not to mention in the worse area.
Actually I want to correct myself....on an LQ9 block it's 100lbs lighter....I'm not entirely sure on a 402 LS2 so I'll gladly admit there may be no weight difference at all. Does anyone happen to know the weight dif?
Edit: sorry EG, didn't even see ya were already on it.
Old Aug 3, 2006 | 04:28 PM
  #49
0EG@EnglandGreen
Supporting Tuner
LQ9 is an iron block. LS2 is aluminium. The LS1 & the LS2 weigh the same
Old Aug 3, 2006 | 10:43 PM
  #50
Darkness's Avatar
Darkness
I have 408 LQ9 in my FRC and cant tell that the motor is 100 or so heavier. One thing is for sure, the iron block runs a LOT cooler than the aluminum!!! Dont know why but I never go above 194F with AC on in traffic on a 100F day.
Old Aug 4, 2006 | 08:33 AM
  #51
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I NEVER have coolant temp issues or does it have a negative effect on any racing I do
Old Aug 4, 2006 | 12:29 PM
  #52
DT's Avatar
DT
Yeah! Saw that on another forum - they didn't say if the $500 was intake only, +TB? or + Rails?
Waiting for someone to get one and get some flow data - I guess someone asked at the show and the rep wasn't sure about the specific release date?
DT
Originally Posted by CNB
The L92 intake is here and costs approximately $500.
Old Aug 4, 2006 | 12:36 PM
  #53
Jackal's Avatar
Jackal
Oh great another drooler. Well here drool some more . .
What I want to know is....WHERE ARE THE WATER PASSAGES?
Old Aug 4, 2006 | 02:54 PM
  #54
2ndVette's Avatar
2ndVette
what you are looking at is one of the early test Warhawk blocks made for mock up purposes only. The "other" LS1 tech site has pictures of the Warhawk block with water jackets.
Old Aug 4, 2006 | 03:39 PM
  #55
Dirty Howie's Avatar
Dirty Howie
Yea..thats news to me also I hope it doesn't significantly affect handling/cornering at the track ...
And my 402 is already being built....so too late to cange for me.
DH
