Low Washer Fluid Warning In Error ???
Old Aug 6, 2006 | 10:02 PM
FrogmanDave's Avatar
FrogmanDave
Default Low Washer Fluid Warning In Error ???
I have a 2002 Z06 and keep getting a 'low washer fluid' warning in the DIC. I completely filled the reservoir, but the warning keeps coming back. I'm assuming the sensor is bad, but was wondering if anyone else has ever had this happen? If so what's involved in replacing he sensor?
Thanks,
Dave
Old Aug 6, 2006 | 10:31 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Mine does that and has for a few years...funny thing is there is no fluid in it as the pump is FUBAR....its just every now and again the message comes up
I have looked at it but I think if you just pull the tank the sensor plugs in the back....
Old Aug 6, 2006 | 10:40 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Rotate the sensor 90deg
Old Aug 6, 2006 | 11:28 PM
JC in XTC5's Avatar
JC in XTC5
Most sensor problems are wiring related, so the first thing to check is the sensor connectors. Sometimes unplugging and replugging will correct the problem.
Old Aug 6, 2006 | 11:34 PM
Dave68's Avatar
Dave68
That warning has popped up now and then but has been good, lately. The thing that bothers me is the leaking fluid that dribbles up on the windshield when I accelerate hard. I have to have a towel handy to clean up the windshield afterwards.
Old Aug 7, 2006 | 12:46 AM
CrazyChris's Avatar
CrazyChris
You can leave the sensor installed in the tank but remove the harness plug from it and you will no longer be bothered with such messages. This is the quick fix
Old Aug 7, 2006 | 08:28 AM
Vette X 3's Avatar
Vette X 3
Actually you likely need to rotate the sensor 180 degrees. If it is in upside down it will set the error even when the reservoir is full. It is a float that needs to be in contact with the other half of the switch when the tank is full.
Old Aug 7, 2006 | 10:47 AM
Mongolink's Avatar
Mongolink
Was that on the inside or the outside of the windshield ?
sorry just couldn't resist !!!
To Low Washer Fluid Warning In Error ???
