Differential Fluid, which do you use?
Old Aug 26, 2006 | 01:32 AM
  #81
Silver Z06 Driver's Avatar
Silver Z06 Driver
Default Rear Diff
Mine leaks.... Always has.... Always will.... I don't care,,,, I just keep pouring in Mobil 1.... Cost is nothing compared to what I spend on tires
Old Apr 5, 2020 | 08:40 AM
  #82
prestonozzy's Avatar
prestonozzy
5th Gear
Originally Posted by DTE Powertrain
We use Redline 75w/140 straight out of the bottle in stock differentials around here and you don't really want to know what we think about that over-priced, stinky snot GM calls differential lubricant... We've tested that lube in the past for HP use w/ added power, racing applications, etc. and it failed miserably in every instance for the areas of use that these HP differentials typically live in.
We still see folks insist on using it for HP applications and we just cringe when we see that, knowing that the differential is screaming for dear life back there.... It might be fine for a 100% stone-stocker car, but that's about it and we wouldn't suggest that lube for *anything* other than grocery-getting type driving...ever.
To each his own though.
DTE
so In your guys opinion for a stock c5 z06 diff I should use the 75/140 over the 75/90 redline because it has more friction modifier in it than the 75/90 and the stock diff needs it?
Old Apr 5, 2020 | 08:43 PM
  #83
ApexClone's Avatar
ApexClone
14 year old necro.
Old Oct 28, 2021 | 06:49 PM
  #84
Music's Avatar
Music
Last time I used Pennzoil 90 weight synthetic diff oil that has the friction modifiers already in it. No problems, however, I had to remove the dog tag from the filler bolt and use an oil safe teflon tape to prevent the filler hole from spraying oil all over the back of the car on long highway drives.
