Clutch Pedal Spring
Old Aug 28, 2006 | 05:00 PM
minytrker's Avatar
minytrker
Default Clutch Pedal Spring
How do you put the spring back in? With my new clutch setup my pedal is really hard to push in. Its hard enough that its messing up my shifting speeds, so Im gonna try the spring again.
Old Aug 28, 2006 | 09:29 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
The trick is to depress the clutch pedal while re-inserting the spring.. Use a lenght of wood between the pedal and the edge of the seat bracket to hold it down while you work.
Old Aug 28, 2006 | 11:18 PM
minytrker's Avatar
minytrker
Cool, I will give it a try. I may need a 2x4 as stiff as the pedal feels
Old Aug 28, 2006 | 11:22 PM
cruisemon's Avatar
cruisemon
You did all this to the pedal on the left side, right? And you're not pushing the dead pedal, right?
Charlie
Old Aug 29, 2006 | 03:26 AM
briann510's Avatar
briann510
Hook the spring on the left eyehole first and back of the pedal bar area it rests in, then push the pedal in and using needlenose pliers grab the right side of the spring and guide it in the right side hole, its failry easy.
Old Aug 29, 2006 | 04:07 AM
minytrker's Avatar
minytrker
You make it sound easy. Mine has been fighting me to the end.
Old Aug 29, 2006 | 07:00 AM
briann510's Avatar
briann510
Trust me, when I was first trying to re-instasll the spring I gave up after 30 minutes and a 5 lbs of sweat.
Then I got back under and figured there must be an easier way and it went right on as explained above. The trick was getting the middle of the spring centered in the recess on the back of the pedal bar, then hooking the left side first, THEN pushing pedal in with a long driver with left hand while needlenose pliering the right side of spring in.
ummm yea I think thats how I did it.
To Clutch Pedal Spring
