How warm does engine need to be?
Old Aug 31, 2006 | 05:24 PM
jbauch357's Avatar
jbauch357
Default How warm does engine need to be?
How warm should I let my oil temp get before I start hammering on the throttle? I drive an 02 Z06, and a friend with an 01 Z06 said to never get on the throttle until oil temp is up to about 180. Thus far I never really push past half throttle or over 2,500 RPM until the oil temp gets past about 170.
Old Aug 31, 2006 | 05:31 PM
bob guzzy's Avatar
bob guzzy
Default temp.
When I used to drag race, Tim Richards said that we should not, get to crazy before 120, sow we used to do burnouts, just generaly screw aroud a little untill we had temp, but I think everyone has there own idea on this, can't hurt to let the engine up to temp. before you go nuts.
Old Aug 31, 2006 | 05:48 PM
WKMCD's Avatar
WKMCD
I've got a full H/C engine and I never take it over 2k until the oil temp is 150. Big spings for the cam are a lot stronger than stock but also more brittle than stock when cold. With stock springs you're probably OK as soon as oil is fully circulaled through the engine and pressure is up.
Old Aug 31, 2006 | 08:00 PM
fixvet's Avatar
fixvet
FWIW.....my '98 doesn't leave the garage until the OT passes 100deg, then I don't push hard until it's over 150deg. It runs like a top and uses no oil after 47K miles. I'm happy!!
Old Aug 31, 2006 | 08:04 PM
LoneStarFRC's Avatar
LoneStarFRC
I usually hold off on anything "frisky" until 170-200.
vettenuts's Avatar
vettenuts
There will be many answers, my personal guidelines that I use are not over 1,500 RPM until 160. Over 160 but under 180, not over 2,000. After 180 then anything goes. I have PSI beehive springs that are quite stiff.
jbauch357's Avatar
jbauch357
Thanks everybody, sounds like I am on the right path. I will continue to baby when cold, and keep my right foot planted when hot!!!
Old Aug 31, 2006 | 09:03 PM
Silver Z06 Driver's Avatar
Silver Z06 Driver
Here in Phoenix when you turn your ignition ON, the temp is 115. I usually hold off till oil temp is 150-160 which is just 2 - 4 minutes.
Old Aug 31, 2006 | 09:09 PM
vettenuts's Avatar
vettenuts
Is that how the women dress out there where its warm
Old Aug 31, 2006 | 09:27 PM
c5chris's Avatar
c5chris
That's what I do. Gas is reasonably cheaper than repairs.
Old Aug 31, 2006 | 09:34 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
165* is my magic number.
Old Sep 1, 2006 | 11:23 AM
TEXHAWK0's Avatar
TEXHAWK0
And I thought I was conservative.
I drive mine "normally" (up to about 3,000 RPM) until I get to 160 degrees oil temperature.
Old Sep 2, 2006 | 03:05 AM
SmashF15C's Avatar
SmashF15C
If I used that philosophy I don't think I'd move much!! I don't think with my G5X2 that the car runs much below 1500 RPM!
Actually, as long as I'm pulling, it's OK, but I can't cruise below 1500, thats for sure.
Hey, did you decide on the exhaust? Don't want to hijack.
Smash
Old Sep 2, 2006 | 04:56 AM
BlownFRC's Avatar
BlownFRC
150 for me
To How warm does engine need to be?
