Flasher locations
Old Sep 2, 2006 | 04:16 AM
jdonnelly's Avatar
jdonnelly
Default Flasher locations
I am having some turn signal issues and need to do some R&R. The emergency flasher works, all the bulbs light but the turn signals blink really fast.
I have heard that there are 2 flashers. One on the fuse block by the battery and the other???
Jeff
Old Sep 2, 2006 | 08:11 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Have you checked all of your connections and bulbs ?
The main reason for the increased flasher speed is the lack of resistance.
Turn signal flasher is behind the hazard switch on your dash, need to pull out vent.
Do a search on it and you should find a bunch of posts.
Old Sep 3, 2006 | 04:43 AM
jdonnelly's Avatar
jdonnelly
I have checked all of the bulbs, which are working. I have not physically checked the connections yet. Is it possible to have this symptom caused by a loose connection and still have the emergency flasher flash at a normal rate?
Old Sep 3, 2006 | 08:00 AM
CorvetteMick's Avatar
CorvetteMick
The turn signal flasher is the flasher as the 4-way. The flasher is built into the button for the 4-way. I had the same problem only intermittent. I changed the flasher and it's worked for 2 years now.
Mick
To Flasher locations
