fan controller advice
Old Sep 25, 2006 | 12:22 AM
Itchy's Avatar
Itchy
Default fan controller advice
Hi Guys,
going to install a constant monitor fan controller and was wondering which is the best one on the market to buy?
Old Sep 25, 2006 | 05:59 AM
vettenuts's Avatar
vettenuts
I am running the Vinci fan controller, there is a small screw that you can use to adjust the temp the fans come on at. I have mine set at 207 on, so it goes off at 201. Works very well and is all pre-wired and plugs right in. Driver's side fan is a bear to unplug though
Old Sep 26, 2006 | 11:27 PM
1Corvette's Avatar
1Corvette
Spend your money on a tune and the tuner can set your fans to run at any temperature that you choose.
Old Sep 27, 2006 | 12:07 AM
Itchy's Avatar
Itchy
Do you recommend the hypertech programmer to do a tune & fans as they want $1200 Aus here for a tune??
Old Sep 27, 2006 | 05:49 AM
vettenuts's Avatar
vettenuts
I wouldn't use the Hypertech, my tuner has told me several times he find people down on power with that unit when they use it. If you are only interested in the fans, the fan switch works great. Both fans come on at the same time and the motor cools down very quickly and runs in a very narrow temperature band.
Old Sep 27, 2006 | 12:51 PM
ersatz928's Avatar
ersatz928
See the $39 Fan Controller Tech Tip : At the CF Home-Page top menu, click on "Other", "Tech Tips", "C5", and read the "C5 Fan Controller" article I wrote.
Old Sep 27, 2006 | 08:08 PM
Mudlizard's Avatar
Mudlizard
Got mine from Mid America and love it. Best money spent to cool the vette and its something that actually does work. It also has the adjustment screw on top to set the fans to come on. Get one, you wont regreat it. And ya, the drivers side fan was a pip to disco. But once you get it, the controller is a piece of cake to put in. I was monkeying around taking my time and it took 30min.
Old Sep 27, 2006 | 08:39 PM
bob guzzy's Avatar
bob guzzy
Default fan control
I got one from summit, daraile, I believe it was works great, I have a 160 stat also car stays around 170 all the time, even in traffic, it is adjustable, I mounted on the barttery box, and picked up the power and the ground right at the fuse block.
I love it I don't like those high temps, like stock. I used one kind or another in the last two c-4's, without problems,
To fan controller advice
