Mythbusters...CF style
Old Sep 27, 2006 | 10:52 AM
brentg454's Avatar
brentg454
How about descreened (non-Z06's) and/or aftermarket MAFs? On a stock engine, of course...
Old Sep 27, 2006 | 11:00 AM
Silver98's Avatar
Silver98
* Mobil 1 synthetic is not the best for your C5
* After market plug wires add Hp
* There is no reason to clean your electrical grounds periodically
* You can program out your TPM system on a 97-99
* Replacing the batteries on your Tire Press Sensors is always successful
* The owners manual and the service manual is only for the other guy to read
* Search functions on this forum are worthless
Old Sep 27, 2006 | 11:18 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Originally Posted by FrankTank
2. Granatelli MAF Sensor Adds HP on stock motor
what about a modified motor? and how much modification would be nessicary to see any benifit from it?
Old Sep 27, 2006 | 11:32 AM
VetteDrmr's Avatar
VetteDrmr
A couple more:
Uncommon paint colors (like mine) are valuable
Mods help resale value
Old Sep 27, 2006 | 12:42 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Originally Posted by AU N EGL
Running the same size tire and wheels on all four corners will cause AH/TC to go
Who said this was a "myth", or that it was busted? Precisely how do you think the TCS system on these cars operate? (Hint; measures the rpm difference between the front and rear wheels..)
Darion's Avatar
Darion
You can do a certain sequence of button pushing, involving the radio and TC buttons, to unleash untold HP.
And I thought the hood seal was good for 25 rwhp not just 15.
Darion
Old Sep 27, 2006 | 12:48 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
D/S rotors look pretty, that's about it
this post contains very little/or no sacarsm
AU N EGL's Avatar
AU N EGL
Busted. AH has nothing to do with differnt size tires wheels or different RMPs of front and rear. Ran 305/35/x18s front and rear
I have done this with noo problems for street driving what so ever. On the track on a high speed sweeper AH kicked in, so I hit the off button and vroom
So running IDETICAL WHEELS AND TIRES front and rear. will not affect AM/TC. However, for best handleing yes you want a less width tire for the front.
Old Sep 27, 2006 | 12:51 PM
HollywoodFRC's Avatar
HollywoodFRC
Default Myth Busters
1) As a Corvette owner, the General (and its dealership network) will take care of you as a valued customer
2) The electrical/electronics system in a C5 is well engineered and reliable
Old Sep 27, 2006 | 12:55 PM
JD's C5's Avatar
JD's C5
If you have had your C5 hasn't had a column lockup by now that you are OK.
If you have had the recall done on your C5 for the column lock that you don't need the CLB
Old Sep 27, 2006 | 12:57 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
according to GM the MN6 01s dont burn that much oil
Old Sep 27, 2006 | 01:05 PM
2kbluestreak's Avatar
2kbluestreak
Air intake turbolators and fuel line ionization devices from JC Whitney improve H.P. and M.P.G. Guarranteed as JCW has been selling such devices for over 50 years!
Old Sep 27, 2006 | 02:00 PM
  #33
VetteDrmr's Avatar
VetteDrmr
Well, I busted it. Running 275 series tires on all 4 corners, never had any problem. The rpm difference isn't enough for the computer to get spooled up about it.
Now, racing my ZR-1 repos, 275/40R-17 and 315/35R-17 rear (rears are smaller diameter than fronts), I do have to run in Competition Mode or all modes off (my normal autox mode). AH still works in this case, but traction control will kick in at some point in my drive to the autox.
Interestingly, it takes anywhere from 1-15 miles before it finally kicks in. Never understood why.
Have a good one,
Mike
Old Sep 27, 2006 | 02:24 PM
  #34
SmoothFRC's Avatar
SmoothFRC
With my Drag Setup, i have 275's all around on 17" wheels, once i hit 50-70mph, my TC kick's in. Did it when my rear tires were new and had more tread then the front.
mine is a 2000 - not sure if that makes any difference, i believe they modified the AH/TC system a couple times during the c5 run.
Also - I have run 295's on my stock rear wheels for 3 years - no problems what so ever, on my second set now.
Old Sep 27, 2006 | 05:30 PM
  #35
z0quick's Avatar
z0quick
Originally Posted by corvette-pilot
Just got one this week
Been driving without one for a few years, even got thru the inspection without it
Oh, and to answer the original question:
160 T-stat
I highly doubt I need one in FL. So this is actually not true unless you are specifying a state.
Old Sep 27, 2006 | 06:28 PM
  #36
Bill Dearborn's Avatar
Bill Dearborn
I run the same diameter tires front and rear at the track and when autocrossing. Have never had an ABS/AH/TC problem due to the tire size. However, if you run smaller diameter tires in the rear than you have in the front the TC system will go crazy. Even in nuetral coasting down a hill it will apply the brakes to keep the rear wheels from spinning to fast (have tried it).
Bill
Old Sep 27, 2006 | 07:32 PM
  #37
Dan_the_C5_Man
I'm sure we can find an equal number of owners that have experienced issues with equally-sized tires front and rear as those that did not, so I stand by my assertion that this issue does not qualify as a "myth". Even if the TCS system doesn't kick-in during "normal" driving, you can bet that the computer will kick-in the TCS sooner than it would with an offset present. And whom here wears down the fronts before the rears? So again it's likely as the rear tires wear you could run into this issue.
To Mythbusters...CF style
Old Sep 27, 2006 | 07:45 PM
  #38
Blue02ws6's Avatar
Blue02ws6
Everyone that posts in the tech section are EXPERTS.
Old Sep 27, 2006 | 10:02 PM
  #39
C5XTASY's Avatar
C5XTASY
Technical BS is NEVER disseminated on the Corvette Forum.
Ed
Old Sep 28, 2006 | 02:25 AM
  #40
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by 97C5ENVY
* 12" wide rims will not stick out on a non-tubbed C5.
or that 335s won't stick out past the fender on z07s.
