probably the reverse switch its on the side of the trans on a manual easy to change and didnt cost much as i remember
john
Two components involved here; the trans switch and a fuse.. Swap the trans switch (approx. 10 bucks at your local auto parts store), if that doesn't solve it replace the fuse as well. Typically the switch fails in such a way to continually pop the fuse.
