brake bleeding
Old Sep 29, 2006 | 04:55 PM
AU N EGL's Avatar
AU N EGL
I made my own cap,
Old Oct 2, 2006 | 08:47 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Thanks for the input.
Old Oct 2, 2006 | 09:55 AM
stormrider's Avatar
stormrider
In what order do you bleed the brakes? I have been told you start with the caliber that is the farthest from the reservoir then work towards the caliber closest to the reservoir. Is the right?
Old Oct 2, 2006 | 10:49 AM
VetteDrmr's Avatar
VetteDrmr
Originally Posted by yellow01
All corvette masters are the same....
Actually, all GM master cylinder caps are the same, at least for late model cars.
And, I made mine very similar to Au N Egl's, cost about $10. Still have to supply the pressure, though.
HTH, and have a good one,
Mike
Old Oct 2, 2006 | 11:26 AM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by Wicked Weasel
  • buy the pressure brake bleeder from Motive for GM cars.
  • buy new brake fluid - Dot3/Dot4 - Valvoline Syn is good for street use
  • raise back of car and take of wheels
  • find bleeder valve - do not open yet (not sure of size wrench)
  • open hood and remove old fluid from reservoir
  • replace with new fluid
  • put the pressure bleeder on the the reservoir and pump to 12-15lbs.
  • make sure the pressure bleeder is not losing air
  • go to bleeder valve and open until new fluid runs through.
  • Close valve.
  • Check reservoir to make sure you are not running out of fluid
  • Check pressure to make sure you are not losing any
  • continue to next tire
something like that.....
Thanks!! I'm going to give this a shot in the next few weeks.
