Help With Shifter!!!
Old Sep 29, 2006 | 08:35 PM
C52000C5's Avatar
C52000C5
Default Help With Shifter!!!
Yea so Im putting my Hurst shifter in right now and need some advice on how to take the T retainer out
Old Sep 29, 2006 | 08:54 PM
zeevette's Avatar
zeevette
The name for that piece is "demon key". And there's two basic ways to remove it. The easiest is to pry the key out using two large flat screwdrivers. Position them on left and right sides, and using pressure wiggle the key out. The other way, which can lead to rounding off the edges of the key, and making removal even tougher, is to use vise-grips to grasp the key, and then hammer underneath the pliers to pop out the thing. If it's really tight, this method can slip off and make the edges hard to hold.
Old Sep 29, 2006 | 08:55 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Use a pair of small vise grips, lock them on, then get a cloth and a screw driver, use the screw driver as a lever to pry up between the cloth / top of the shifter **** and the vise grips. It helps to wiggle the vise grips back and forth as well. Be mindful that the key is lead, so it is soft.
Old Sep 29, 2006 | 08:58 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Hence the name... It is a PIA but after you have it off a few times it is a breeze. I like the flat tip method, just be careful not to leave a mark on the top of the ****. You can do it!
Dave
Old Sep 29, 2006 | 09:47 PM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
Please dont forget to tighten and loctite the set screws on the front and back of the shift base. Why you ask? Because eventually (if not properly tightened) they work them selves loose and screw them selves into the base thus, preventing shifting into either 1,3,5,r (front set screw) or 2,4,6 (the rear set screw). Most people find this out the hardway and the entire console has to come back out to get things tighened properly. Plus you wont get stuck with only the upper or lower half of gear while traveling!
Cheers!
Old Sep 29, 2006 | 09:52 PM
TRACKMAN2's Avatar
TRACKMAN2
no **it i recovering from the knot on my head from removing that verry peice at the track today.. when she comes loose she comes loose in a hurry
Old Sep 29, 2006 | 10:29 PM
Dave68's Avatar
Dave68
Here's my method - wrought from the school of the impact wrench......
http://www.conceptualpolymer.com/corvette_install.htm
Old Sep 29, 2006 | 10:44 PM
C52000C5's Avatar
C52000C5
Default Thank You
I got it and finally finished. The flathead screwdriver method worked perfect I can't elieve how much better the shifts are now. I wish i did this when I bought her. Thanks Again
Old Sep 30, 2006 | 08:11 AM
chiefDave's Avatar
chiefDave
Cheers!
IMO remove the stops, as that way they can not come loose and strand you, locked out of 1,3,5 or 2, 4, 6, r. The T56 has stops built in, and there are realy no need for these. Lots of folks here have run into it. Just keep an eye on them man, as we do not want to see you get caught ou there. Congrats on a great mod!
Dave
Old Nov 4, 2006 | 10:31 AM
C5Jimmy's Avatar
C5Jimmy
Tried to get the demon key out this morning to install my new Hurst shifter.
I can't believe how hard it is to get the damn demon key out!
I tried to pry with the screwdrivers with even , constant pressure, the tabs broke! Ddin't think I needed safety glasses on this job, but the one piece hit me in the head, if that hit my eye, I'd be blinded and in the ER right now! Also, sprayed WD40 in there, to no avail. Next, I tried the vise grip method, and the key was breaking where I put the vise grips!
It seems like this thing is made outta pencil lead!
Still have to get it out somehow, and have to get a new key!!!
Old Nov 4, 2006 | 11:40 AM
TEXHAWK0's Avatar
TEXHAWK0
I took the time to make a tool to fully engage the ears on the key since I knew it was soft. Mine was tight but the tool worked. The tool is just a piece of flat bar that I bent in a vise, then filed a slot in to fit the key.
I have also found that sometimes it is better to apply the pressure quickly (like an impact) instead of gradually. Often, a bolt, or whatever you are trying to loosen, will break loose before it deforms, where steady pressure will just round it off.
If you destroy the top, you may have to drill it out. Once you remove some metal from the center of the key, it should relieve the pressure on the key and make it easier to remove. You could also tap the hole and insert a bolt to give you something else to grab onto.
Old Nov 12, 2006 | 04:12 PM
EMINENT 1's Avatar
EMINENT 1
Just cut down my shifter 3/4 inch. That demon key would not budge, but thanks for the vise grips tip! That got it done and the demon is now banished forever!!! The **** goes on tight. There was really no use for it from the factory. I will going for a test drive in a bit with my new $5 shifter. That's the way I see it as it was about 5 bucks for the cutting wheel for the Dremel.
To Help With Shifter!!!
